Author Topic: Help setting up uart  (Read 546 times)
Offline DothosTopic starter
« on: February 21, 2011, 10:15:16 PM »
I have been searching everywhere and i'm still not sure how to use a uart on my axon 2 to communicate with a pc through a serial port i would like to know the pinout and if I need to use extra hardware to do it.
thanks in advance
  • Helpful? 84
Re: Help setting up uart
« Reply #1 on: February 22, 2011, 08:02:08 AM »
The Axon's pins are 5V logic and the serial COM port on a PC is RS232 levels (google this).
At a minimum you need a MAX232 chip to translate to voltage level between the Axon and PC.
Look at the SoR tutorials above for more info.
Offline Crunchy Theory
  • "Well great is ok, but amazing would be great."
« Reply #2 on: February 27, 2011, 02:50:38 PM »
If all you want to do is use the UART to communicate with the Axon through your PC, you should just use the USB connector on it. All you need to is install the driver from SILabs (https://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx) so that your PC's terminal program or whatever will recognize the Axon.
Edit: just read this part of the Axon2 setup tutorial: http://www.societyofrobots.com/axon2/axon2_setup2.shtml. It should be pretty straightforward.
« Last Edit: February 27, 2011, 02:52:36 PM by Crunchy Theory »
The only way to top an upright screen, keyboard, and mouse is to eliminate the need for humans to touch a PC at all. Oh, hello there Mr. Robot... what would I like you to do, you ask?
Last post August 02, 2006, 03:21:07 PM
Last post July 11, 2007, 06:40:01 PM
Last post April 18, 2008, 04:46:14 AM
by hazzer123
Last post April 21, 2009, 05:18:05 PM
by SmAsH
