Author Topic: how to determine clock error rate of microcontroller?  (Read 951 times)
Offline Aberg098Topic starter
« on: February 17, 2011, 12:05:22 PM »
Apologies for reviving an old thread...
How exactly did you accomplish this testing Admin? What did you hook up your oscilloscope to? What did you use as a reference time?
I am trying to use the timing function to measure the time needed to execute a portion of code. In essence, similar to what you did for measuring the delay function.
« Reply #1 on: February 23, 2011, 11:40:00 AM »
method 1:
Have your mcu keep track of time for an hour. When the hour is done, check your actual clock to see how much real time has passed.
method 2:
Have your mcu creating a square wave using delay_ms(10). Then measuring the period using an scope, see how much it's deviated from what the oscope considers 10 ms.
« Reply #2 on: February 23, 2011, 12:01:30 PM »
So in essence, you were using your oscilloscope as the standard reference point for time?
Also, you stated that your results were accurate to 0.58% of your reference time: This is unclear to me.
« Reply #3 on: February 23, 2011, 12:10:24 PM »
yeap
It means the error was 0.58% off. So if I let it run for an hour, the cumulative error would have been ~21 seconds. (60 minutes * .0058 = 0.348 minutes)
Offline Webbot
  • Helpful? 107
« Reply #4 on: February 23, 2011, 12:51:23 PM »
And don't forget the oscillator that is supplying the clock to mcu will have a tolerance - it may not be exactly 16MHz in all conditions (eg temperature etc)
« Reply #5 on: February 23, 2011, 04:41:33 PM »
Is the clock tolerance something that is easily known? As in typical information you'd find in a datasheet?
« Reply #6 on: February 23, 2011, 05:39:31 PM »
Nope, it can only be determined experimentally. Good design technique and luck can improve accuracy, but not determine the exact amount of error.
It's also a function of the capacitors tolerances, the capacitance difference between both capacitors, and even the PCB tracings.
Aberg098, would a real time clock RTC be what you are looking for? You can buy one and interface it with the Axon, if you need very accurate timing over long periods of time.
ps - this has gone off topic, so I've split this from the original thread
Re: how to determine clock error rate of microcontroller?
« Reply #7 on: February 24, 2011, 09:24:30 AM »
Well, to be honest, I'm trying to get away using only the Axon clock for my application, however I'm unsure as to whether or not it's sufficient.
I am Using the Axon for datalogging inertial measurements, and sending those measurements back through the UART to a computer. For this, I need some pretty accurate time stamps to go with the measurements. I'm currently getting about a 70Hz measurement frequency, and I'm aiming to be able to run tests for at least one hour.
As for Interfacing a RTC to the Axon: I assume you read this much like you would read a sensor... Any suggestions. All the ones I can seem to find don't give me anything past seconds. Since I'm running at a pretty high frequency, I'd need something in the millisecond range.
Offline Webbot
  • Helpful? 107
« Reply #8 on: February 24, 2011, 01:14:15 PM »
I know that madsci has used the scheduler in WebbotLib to sample a sensor on a reular basis - can't remember if it was every 10Hz or every 10ms. Think he was using it for a Kalman filter.
Madsci may want to explain
Last post November 17, 2007, 07:15:05 PM
by Hester EE
UART error rate?
Started by Admin « 1 2 » Electronics
Last post January 22, 2008, 11:05:33 AM
by dunk
Last post April 09, 2008, 02:52:38 AM
by superchiku
Last post September 22, 2008, 10:23:36 AM
by pomprocker
