Author Topic: selection of a robot servomotor  (Read 1401 times)
chabo88
  • Guest
« on: February 24, 2011, 02:31:12 AM »
we are designing a 2 axis robot arm. after calculating the motors torque needed(3000Nm), how should i proceed to select my motor and which servomotor is better for my appilcation(helical, planetary,bevel...)
  • Helpful? 84
Re: selection of a robot servomotor
« Reply #1 on: February 24, 2011, 11:45:43 AM »
Is the type of gears in the gearbox not the type of servo motor.
Here is a link to a gear motor manufacture that has info on motor selecting.
 http://www.micromo.com/technical-library.aspx
The articles and paper there should answer your question.
Offline nickc
« Reply #2 on: February 24, 2011, 02:22:46 PM »
Here's  some links to motion control suppliers we have used at work.
http://www.compumotor.com/
http://www.parkermotion.com/products/Gearheads_and_Gearmotors____30_32_80_567_29.html
http://www.parkermotion.com/pdfs/Gen_II_Gearhead_PS_Output_Shaft_Loading.pdf
http://www.seweurodrive.com/produkt/index.php
http://www.sew-eurodrive.kr/?mid=product_gear
Their catalogs/pdf's have lots of good info. They also have a motor/system selector to help you decide.
I've used their ACR controller from parker to build a multiaxis system and it has a nice set of DLL's to write your own windows based HMI if you want or you can use the software they provide too.
If you look at the link you'll see most joints with that kind of torque are single or multi stage helical-planetary or helical-planetary-spiral-bevel depending on whether the motor is inline or right angle and what reduction ratio you want.
Last post August 10, 2007, 02:27:54 PM
by HDL_CinC_Dragon
Last post March 26, 2009, 04:56:46 AM
Last post November 11, 2009, 11:21:20 AM
by Razor Concepts
Last post May 05, 2013, 09:01:20 PM
by jwatte
