Author Topic: Help with understanding reverse voltage  (Read 1666 times)
Offline dex2tekTopic starter
« on: June 18, 2007, 02:52:34 AM »
Has anyone built sandwich the robot?, I dont understand how reverse voltage works (flyback diodes), and how the reverse diode is  then hooked up to the motor. If anyone has anyone has any information it would really help
Re: Help with understanding reverse voltage
« Reply #1 on: June 19, 2007, 06:40:07 PM »
So normally current passes through a transistor/MOSFET in just one direction. If current goes in reverse, bad stuff will happen. With motors, there is a lot of noise. If the motors are suddenly torqued, they apply a voltage to the power lines (noise).
Sometimes this noise is so large that it sends a current in reverse through the transistor/MOSFET, thereby frying it. So what a flyback diode does is allow this 'flyback' current to bypass the transistor and instead go back to your battery.
Does that help?
Last post February 08, 2008, 01:27:49 AM
by krich
Last post July 19, 2008, 02:26:31 PM
by izua
Last post October 25, 2008, 05:53:40 PM
by gamefreak
Last post February 06, 2009, 05:24:03 PM
