Author Topic: Different of ENCODER and POTENTIOMETER?  (Read 397 times)
Offline bubbletea7Topic starter
« on: February 25, 2011, 02:36:03 PM »
Hello there,
what is the different between them in term of position sensor?
i make a dc motor controller for positioning application using a Encoder to count up my rotation of the motor?
can the potentiometer replace the encoder?
tq
Offline hopslink
  • Helpful? 14
Re: Different of ENCODER and POTENTIOMETER?
« Reply #1 on: February 25, 2011, 06:08:53 PM »
The encoder is typically a digital output, non contact sensor and the potentiometer relies on physical contacts and has an analogue output. Position sensors will cope with continuous rotation just fine, where most potentiometers have limited rotation - you can get continuous rotation pots but expect to pay a premium.
Yes, but it is not recommended. Since potentiometers rely on physical contacts they have a limited lifespan so are likely to prove unreliable long term. You can buy better quality pots with longer lifespans but you save little, if any, over the encoder option and still ultimately have a less reliable solution.
Last post August 02, 2007, 02:22:21 PM
by hazzer123
Last post October 24, 2007, 08:50:51 PM
by HDL_CinC_Dragon
Last post December 07, 2007, 09:00:44 PM
by paulstreats
Last post May 23, 2008, 07:03:10 PM
by Webbot
