Author Topic: is a stuck mosfet fixable?  (Read 830 times)
Offline BANETopic starter
  • E=roboticsC^2
« on: February 27, 2011, 04:14:39 PM »
Hello all,
It turns out i accidently hooked up my N channel mosfet from radio shack wrong and now it is stuck open.  is it possible to un stick it or is it junk?
thanks
« Last Edit: February 27, 2011, 05:21:00 PM by BANE »
Re: is a stuck mosfet fixable?
« Reply #1 on: February 27, 2011, 05:48:34 PM »
It's toast.
  • E=roboticsC^2
« Reply #2 on: February 27, 2011, 06:04:38 PM »
It's toast.
as i feared :'(.........good thing im passing by radio shack tomorrow
« Reply #3 on: February 27, 2011, 06:17:01 PM »
Yes, you probably got either the gate-drain or the drain-source welded together internally.
A large-ish current through it might reveal which, by the voltage drop over it - drain-source welded would give a ~0V drop, gate-drain would have a slightly higher drop (but you may need to compare it with a good one by connecting the gate and drain).
Last post November 20, 2008, 04:26:03 AM
by octagonx
Stuck!
Started by retardme Misc
Last post January 03, 2009, 09:41:09 PM
by jamort
Last post November 25, 2009, 06:31:04 PM
by BinarySlave
Last post October 12, 2010, 06:35:25 AM
by abexomotron
