Author Topic: Sharp Ir always shows 30 cm?  (Read 740 times)
Offline greasemonkey94Topic starter
« on: March 01, 2011, 06:00:12 AM »
Hello,
I just recently finished building my robot, it has a sharp IR gp2d12 sensor on a servo for basic obstacle avoidance,
I'm using an arduino uno and l293d motor driver.
It worked beautifully(relatively, remember this is my first bot!!) for a while and then it seemed to detect obstacles all
the time, it never went straight.
It seems to stop working after the unplug the battery, I have 2 power supplies a 12 900mAh NiCd for the motors and
a 9V battery for the arduino (i haven't forgotten common ground, I checked  ;D)
It seems to work fine for sometime and then goes completely haywire, this has happened 3-4 times, each time i reloaded the code :(
Does anyone know whats wrong or what im doing wrong, tell me if you need picks of my setup.
Is this a hardware or software problem??. It gives weird readings like 30cm,14cm etc (i powered the uno thoguht the usb and saw the readings via serial) even when when i tilt it towards the ceiling and there is no object to be seen .
here is the code I'm using
Basically whats its supposed to do is move straight until it finds an object, then it stops and scans 90 degrees to its left and right and then moves in the direction of greatest object distance.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int motor_left[] = {2, 3};
int motor_right[] = {7, 6};
int IRpin=0 ;
void setup()
 myservo.attach(9);// attaches the servo on pin 9 to the servo object
 // Setup motors
 int i;
 for(i = 0; i < 2; i++)
  pinMode(motor_left[i], OUTPUT);
  pinMode(motor_right[i], OUTPUT);
void loop()
 myservo.write(90);
 delay(250);
 int sharpir=getsharpdata();
 drive_forward();
 if(sharpir<20)
   servo_scan();
// --------------------------------------------------------------------------- Drive
void motor_stop()
 digitalWrite(motor_left[0], LOW);
 digitalWrite(motor_left[1], LOW);
 digitalWrite(motor_right[0], LOW);
 digitalWrite(motor_right[1], LOW);
 delay(250);
void drive_forward()
 digitalWrite(motor_left[0], HIGH);
 digitalWrite(motor_right[0], HIGH);
void drive_backward()
 digitalWrite(motor_left[1], HIGH);
 digitalWrite(motor_right[1], HIGH);
void turn_left()
void turn_right()
float getsharpdata()
  float val = analogRead(IRpin);
  float distance = (2914 / (val + 5)) - 1;
  delay(50);
  return distance;
void servo_scan()
 motor_stop();
 myservo.write(0);
 delay(1000);
 int left=getsharpdata();
 myservo.write(180);
 delay(1000);
 int right=getsharpdata();
 if(left>right)
  turn_left();
  delay(500);
else
   turn_right();
   delay(500);
Any and all help appreciated hehehe  ;)
« Last Edit: March 01, 2011, 06:21:47 AM by greasemonkey94 »
Offline rbtying
  • Helpful? 31
Re: Sharp Ir always shows 30 cm?
« Reply #1 on: March 01, 2011, 08:57:40 AM »
The sensor itself has a maximum range of 80 cm and a minimum range of 10 cm.  You're using the SharpIR reading code for a 4cm to 30cm; as I remember, the code for the GP12D12 is this:
float distance = 5 * 2769 / 2 * value * pow(value, -.9988);
Which could of course be wrong - try it out.
If you want to see if its a hardware or software problem, look at the voltages coming out of the sensor (voltage = analogRead * 5.0 / 1024.0) and see if they're stable at a certain distance.  If they fluctuate wildly, that could be your problem.  Otherwise, it's probably your code.  You could also try averaging 3 values to get a more normalized response, as well.
In your getsharpir function, you make some strange decisions:
the return value from analogRead(pin) is an int: don't make it a float until you have to, because Arduinos do not have floating point coprocessors
the delay(50) doesn't do anything other than make it slower - remove it.
  • Helpful? 84
« Reply #2 on: March 01, 2011, 08:58:23 AM »
You'll need to determine if its the voltage from the IR range finder or if its the processor that is behaving incorrectly. Then if its the processor determine if its a hardware or software issue.
Some testing can be done by replacing the IR range finder with a Pot wired into the processor's ADC. If this seems to work correctly leave the pot on the processor and power the IR range finder as before.
The Sharp IR range finders do draw huge current when its switches on the IR LED and can cause havoc with the processor. Search these forums for several discussions about this problem and solutions.
« Reply #3 on: March 01, 2011, 09:21:13 AM »
thanks waltr and rbtyping,
rbtyping, i tried your code, but all i got was 6922 :(,
I dont think its a problem with the calcluation because it worked fine just a few days ago and I
havent changed anything in the code,
i used delay(50) because i thought that it could take readings only ever 30 ms, am i wrong??
« Reply #4 on: March 03, 2011, 08:05:25 AM »
Hmm I think theres a prblem in the code,
I modified my code and now im taking the average of 5 readings and
using just raw a2d data instead of converting it into Centimeters.
heres the code
#include <Servo.h>
int IRpin=0 ;
int avgdistance=0;
int val[5];
void setup()
 pinMode(0, INPUT);
 // Setup motors
 int i;
void loop()
 myservo.write(90);
 delay(250);
 drive_forward();
 if(sharpir>330)
   servo_scan();
void motor_stop()
 delay(250);
void turn_left()
void turn_right()
  for(int i=0;i<5;i++)
   val[i] = analogRead(IRpin);
   // Calculate linear slope of reading (thanks, Acroname!):
   avgdistance+=val[i];
   delay(10);
   avgdistance=avgdistance/5;
   return avgdistance;
void servo_scan()
 motor_stop();
 myservo.write(0);
 delay(1000);
 myservo.write(180);
 delay(1000);
 if(left>right)
  turn_left();
  delay(500);
else
   turn_right();
   delay(500);
It seems to work ok for now,
Here is a crappy video of it in action
http://www.societyofrobots.com/robotforum/index.php?topic=13397.0
Last post May 22, 2006, 08:21:14 AM
Last post June 17, 2008, 02:33:27 AM
by photray94
Last post February 15, 2009, 11:47:25 AM
by DemonDomen
Last post November 28, 2009, 02:48:28 PM
by Charizard
