Author Topic: My Servo won't turn off!!!!  (Read 496 times)
Offline shiko250Topic starter
« on: March 04, 2011, 09:22:29 AM »
No matter how I program my Axon 640 (that I just received) my servo is always on as soon as I turn on the Axon, no matter what pin I plug it into. How do I fix this?
Re: My Servo won't turn off!!!!
« Reply #1 on: March 04, 2011, 09:54:03 AM »
Always on?
Do you mean always running?
If so, does it run regulary or irregulary?
Offline dmclifton
« Reply #2 on: March 04, 2011, 12:04:11 PM »
Are you sure you are putting it on properly, i.e. ground (black) to the outside if you are using an Axon?
« Reply #3 on: March 04, 2011, 12:18:44 PM »
Sorry I was very non-descriptive of my problem.
I have a servo motor (Hitec HS-422) that I plug directly into my Axon 640 microcontroller (yes black wire to the outside). The motor deems to receiving direct voltage from the battery(no PWM) because it runs at a steady rate. It runs as if I had plugged the battery directly to the servo. I have been trying to figure this out for hours, turning on/off ports, changing code, and even putting in no code and still the same problem.
« Reply #4 on: March 04, 2011, 02:26:50 PM »
Figured it out... The Electrical Engineering department modified all the servos to be straight DC motors. So i was trying to run a DC pmotor off the port. I'm just lucky I didnt fry anything. Thanks anyways.
Last post February 27, 2008, 09:04:50 PM
Last post May 16, 2010, 02:24:20 AM
by Actives
Last post January 12, 2011, 09:28:14 PM
by offencerobotics
Last post March 02, 2011, 06:23:17 AM
by daisordan
