Author Topic: SRF05 sensor C18 code  (Read 1309 times)
Offline daisordanTopic starter
« on: March 04, 2011, 04:24:36 PM »
I am currently using PIC18F4455 chip to write a C18 code with SRF05 sensor. After i finish my code, it doesn't work. If i try to run it one by one like just run the "trig_pulse", RD2 will output a pulse to the sensor. But now if i try to run them together, there is no respond on the sensor. RD2 no output signal and RD3 no feedback. What is the program with my code?Do i have to use interrupt? I have look through many example of interrupt but still dun understand how to do it . It will be very helpful if someone can give me a hand on it :(..Many Thanks!!
unsigned char distance;
void main (void){
   TRISD=0b00001000;      //set RD3(Echo)=input,RD2(Trigger)=output,RD6(servo)=output
while(1){
   set_timer1();
   while(1){
   trig_pulse();         //send pulse to trigger
   while(!PORTDbits.RD3);          //wait Echo goes high
   measure_pulse();
   distance = TMR1H + TMR1L;
   distance /= 58;
void trig_pulse (void){
   LATDbits.LATD2 = 1;
   Delay1TCY();
   Delay1TCY();
   Delay1TCY();
   LATDbits.LATD2 = 0;
   Delay1KTCYx(10);
void measure_pulse (void){
   PIR1bits.TMR1IF = 0;
   T1CONbits.TMR1ON = 1;
   while(PORTDbits.RD3);   //wait Echo goes low
   T1CONbits.TMR1ON = 0;
void set_timer1(void){
            OpenTimer1(TIMER_INT_ON &   //interrupts enable
            T1_8BIT_RW &
            T1_SOURCE_INT &
            T1_PS_1_1 );
            INTCONbits.GIEH = 1;
  • Helpful? 84
Re: SRF05 sensor C18 code
« Reply #1 on: March 04, 2011, 04:40:14 PM »
To learn how to use interrupts and the other feature in PIC do this tutorial:
http://www.gooligum.com.au/tutorials.html
« Reply #2 on: March 06, 2011, 04:12:37 PM »
thx for ur link
i have go through all the topic and i think i did all the things he say in the interrupt topic.. Like "set_timer1" this part..
wt else should i write here?
Last post December 02, 2008, 02:55:43 AM
Last post December 05, 2009, 03:57:55 AM
by ozbot
Last post May 30, 2010, 09:27:53 PM
by Xyver
Last post March 12, 2011, 06:54:55 PM
by waltr
