Author Topic: High School Student//Robocup Junior Soccer Competition advice  (Read 1191 times)
Offline ericsmallsTopic starter
Hi everyone,
My High school's robotic club is working on designing a robot for the Robocup Junior soccer competitions http://rcj.robocup.org/soccer.html
But this is our first year, so we have a lot of questions, and I'm confident you guys will be able to help.
First off, is there any place where we can buy sheets of aluminum or carbon fiber, which will serve as  chassis for our robot, or would we have to buy it and cut it?
Is there an easier way?
Also, is anyone familiar with the kicker and dribbler system robots use to capture and kick the ball?
That's our biggest hurdle so far   :\
On the other hand, doing some research, we've noticed teams using a pair of photo-resistors//photo-transitors that signal when the ball is captured in the dribbling system.
Does anyone know, how that actually works?
Thanks guys, that's all for now!! ;)
Offline Jak24
Re: High School Student//Robocup Junior Soccer Competition advice
« Reply #1 on: March 08, 2011, 12:36:09 AM »
HI!
I am also a Robocup Junior competitor, :P
Hi everyone,
you came to the right place  ;)
Well unless you want to build a lego chassis, then there isn't really an easier way  ;D
you have to buy the aluminum, carbon-fiber yourself, and then cut it.
I know that these guys sell carbon-fiber:
http://www.robotmarketplace.com/store.html
but otherwise I recommend using plastics, or Plexiglas, which is much better/ lighter.
the best type of kicker is a solenoid, or if you want a REALLY good kick, look into pneumatic systems.
the dribbler is just one or two smaller motors with a rubber wheel attached to them, nothing fancy.
yes that is a very common way to see if the ball is captured, it basically works as a tripwire.
when the photo-transistor can't see the Ir light from the emitter then you know there is something in the way,
(not always the ball)
 but also remember you need to use photo transistors for ball sensing,
i recommend just using 2 tactical switches, or any touch sensitive sensor, and putting it in the ball capture area
that way you will have a better idea if the ball is there.
Regards
Jak24
Last post December 31, 2007, 10:49:48 PM
by david_or_johnny
Last post August 31, 2009, 07:18:30 AM
by kpmcgurk
Last post October 14, 2010, 06:15:09 PM
by Gertlex
Last post July 22, 2011, 09:11:16 PM
by mstacho
