Author Topic: microcontroller review  (Read 1536 times)
Offline shyamgeniousTopic starter
  • TECHNO GEEKS AND SCIENTISTS ROCK BUT DO YOU??
« on: March 10, 2011, 02:29:14 AM »
The microcontroller im about to buy has the following things.im making a four wheeled thingy -which "does not barely commit suicide by driving of the table".i want it for future modification and make a more advanced and expensive robot.are these feautures enough?? or do i need more? plz let me know .
here are the specifications
Advanced RISC Architecture
Up to 16 MIPS Throughput at 16 MHz
64K Bytes of In-System Self-Programmable Flash
8K Bytes RAM
4K Byte Internal SRAM
86 Programmable I/O Lines arranged in nine 8 bit ports
In-System Programming by On-chip Boot Program
JTAG
16-channel, 10-bit ADC
Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes
Four 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
Real Time Counter with Separate Oscillator
Twelve 16 bit and Four 8 bit PWM Channels,
Four Programmable Serial USART
Eight external interrupts
Master/Slave SPI Serial Interface
Byte-oriented Two-wire Serial Interface
Programmable Watchdog Timer with Separate On-chip Oscillator
100 pin TQFP package
for further info plz go here- http://www.nex-robotics.com/atmega640-development-board/atmega640-development-board.html
regards
shyamgeni
The wise only need a hint to know whats going on.The fools cannot understand even if its given in writing.You decide-
 which are you?
regards,
ShyamGenious
Offline dmclifton
Re: microcontroller review
« Reply #1 on: March 10, 2011, 09:41:05 AM »
This is the same chip (the 640) used on the Axon which admin sells here (click Axon MCU on main site).
I'm not sure about the connection setup of the dev board, somebody more experienced might have some thoughts.
Offline richiereynolds
« Reply #2 on: March 10, 2011, 04:02:48 PM »
That's a lot of features, you could probably get away with much less though I'm sure they wouldn't go to waste if you've bigger plans for it in the future. What price is it?
« Reply #3 on: March 10, 2011, 06:52:19 PM »
Not trying to rain on your parade, but it sounds like you are gonna just buy the microcontroller chip, so just in case, you should be aware that a 100 pin TQFP package might be a little out of your league to solder.
You might wanna start with a DIP-40... And you can get more power in a DIP-40 than you'll need for the first couple of years.
« Reply #4 on: March 11, 2011, 01:54:37 AM »
its 40 dollars minus shipping
 which are you?
regards,
ShyamGenious
« Reply #5 on: March 11, 2011, 02:11:42 PM »
If it's that whole development board from your link I think that's pretty good value. Plenty of scope for experimenting on there.
« Reply #6 on: March 11, 2011, 09:49:06 PM »
with accessories too
Kit Contains
1- ATMEGA640 Development Board
1- USB Cable
1- DB9 Serial Cable
10- 1 to 1 jumper cables
1- Documentation CD
5- 2 Pin Jumpers
 which are you?
regards,
ShyamGenious
Last post May 15, 2007, 11:01:40 AM
Last post February 17, 2008, 01:42:11 PM
Last post March 09, 2011, 08:47:46 PM
by dellagd
Last post May 21, 2011, 09:59:21 PM
by aruna1
