Author Topic: optical interrupt encoder on roller chain?  (Read 771 times)
Offline dacbTopic starter
  • Hybrid power
« on: March 11, 2011, 01:18:34 PM »
I'm wondering if anyone has any experience or thoughts on a roller chain based optical interrupt encoder.  Imagine a motor that drives a wheel using standard roller chain, e.g. #25, 1/4 pitch.  The open space in the links of the chain transmit the light and the pins in the chain block it resulting in a pulsed encoder signal.
I can imagine a problem related to chain tension that might result in the chain contacting the transmitter or the receiver, but that should be surmountable by placement and design.
Thanks!
Offline vinniewryan
Re: optical interrupt encoder on roller chain?
« Reply #1 on: March 11, 2011, 03:35:28 PM »
The best way to ensure the chain will not come in contact with the encoder is to use a laser diode with plenty of distance from the chain as your light source.
« Reply #2 on: March 12, 2011, 12:37:45 AM »
[...] Imagine a motor that drives a wheel using standard roller chain, e.g. #25, 1/4 pitch.  The open space in the links of the chain transmit the light and the pins in the chain block it resulting in a pulsed encoder signal.
Imagining... Resolution = Wheel diameter x Pi / number of cogs.
Besides, it would be just as easy to just measure the cog wheel, either optic or eg. by a Hall element.
Yes, a dual pulley chain tensioner, with the optic components mounted in between the two pulleys - no slack there... But why bother, there's better ways to get low-res odometry?
Last post May 07, 2008, 05:09:15 PM
by pomprocker
Last post October 19, 2008, 01:20:43 PM
Last post February 25, 2009, 04:00:34 PM
Last post April 10, 2012, 07:18:17 AM
by jkerns
