Author Topic: charging batteries using motors  (Read 877 times)
Offline ballbreakerTopic starter
« on: March 12, 2011, 10:43:15 AM »
I have searched the internet to find an answer but i didn't find what i was looking.
am trying to charge a battery by spinning motors but the obvious question is when i connect them the battery will give energy to the motors how do i stop the battery from giving power but to take power from the motor and charge?
also what other things i have to be aware of?
thank you
For Those About To Rock, We Salute You!
  • Helpful? 84
Re: charging batteries using motors
« Reply #1 on: March 12, 2011, 11:02:48 AM »
Simplest is a single diode to allow current to only go from the motor to the battery.
« Reply #2 on: March 12, 2011, 05:46:52 PM »
Hand spinning or by a windmill or similar?
If spinned by hand, either use gearing to get it spinning fast or use a stepper motor.
A stepper will take a couple of diodes, as there's 2 or 4 phases (depending on whether the motor is a unipolar or a bipolar type), but small steppers are very efficient with even modest spin rates.
« Reply #3 on: March 14, 2011, 10:37:31 AM »
thank you for your response and am sorry that i didnt reply earlier
its going to be most likely a brushless geared motor (with permanent magnets) i have thought about the diodes but because am using 12V i thing it will quickly overheat wouldn't ? also if the voltage created gets higher than 12V can a 12V voltage regulator keep it down?
btw is the brushless motor  better as a generator rather than a normal dc motor?
« Reply #4 on: March 14, 2011, 12:32:15 PM »
No. You just need to choose diodes that fits the output (V&A).
How much higher, at what currents and what specific regulator.
Haven't ever tried one that way, but I'd think they were more efficient than a brushed motor - you'll need a rectifier for each phase winding though.
Last post December 11, 2007, 02:07:46 PM
Last post March 22, 2008, 11:53:26 AM
by ed1380
Last post June 21, 2008, 11:35:13 AM
Last post June 01, 2010, 05:50:02 AM
by z.s.tar.gz
