Author Topic: SRF05 sensor  (Read 1138 times)
Offline daisordanTopic starter
SRF05 sensor
« on: March 12, 2011, 01:40:08 PM »
I have writen up the code for my SRF05 sensor with 18F4455 with MPLAB. When i just run the code, its working fine. But now if i put any code in the main..like LED flashing... The whole sensor doesnt work. I didnt use isr for my sensor measurement, is that case my whole sensor not working??
Offline rbtying
  • Helpful? 31
Re: SRF05 sensor
« Reply #1 on: March 12, 2011, 01:45:42 PM »
Post code.
Re: SRF05 sensor
« Reply #2 on: March 12, 2011, 02:26:49 PM »
unsigned int distance;
void set_timer0(void)
    OpenTimer0(T0_16BIT &
                T0_SOURCE_INT &
                T0_PS_1_1 );
void trig_pulse (void)
   LATDbits.LATD2 = 1;
    Delay10TCY();
      LATDbits.LATD2 = 0;
    Delay10TCYx(20);
void measure_pulse (void)
    while(PORTDbits.RD3);
    T0CONbits.TMR0ON = 0;
void main (void)
    LATDbits.LATD2 = 0;
    TRISD=0b00001000;
   while(1)
       trig_pulse();
      set_timer0();
       while(!PORTDbits.RD3);
       measure_pulse();
        distance = (int)TMR0L + (int)TMR0H << 8;
       distance /= (int)58;
Re: SRF05 sensor
« Reply #3 on: March 12, 2011, 03:22:05 PM »
Or maybe somethings wrong with the MPLAB setting? When i plug in PICkits to program the chip ( only sensor code), the sensor is working(power from PICkit). Now i program it, plug out PICkit, connect the chip to another power supply, the sensor doesnt work .
  • Helpful? 84
Re: SRF05 sensor
« Reply #4 on: March 12, 2011, 06:54:55 PM »
Post all of the code including the Config bits, includes and variable definitions.
Are you building DEBUG or RELEASE code? MPLAB tool bar drop-down.
Have you run/stepped through your code in MPLAB's Simulator?
Last post November 28, 2008, 12:11:20 AM
Last post December 08, 2008, 07:52:04 AM
by MaltiK
Last post March 06, 2011, 04:12:37 PM
by daisordan
Last post October 01, 2012, 10:53:56 AM
by VOne
