2
Author Topic: Pan/tilt motor specifications  (Read 2023 times)
Offline tenrinhoTopic starter
« on: March 15, 2011, 08:57:53 AM »
Hi everyone,
I'm new to the forum (found a lot of usefull threads :) thanks!) and new to Pan/tilt motors.
I want to use a motor to control the yam and pitch angles of a camera. Something like this:
http://www.servocity.com/html/spt200_pan___tilt_system.html
http://www.trossenrobotics.com/store/p/3139-Pan-and-Tilt-Kit-with-Servos.aspx
http://superdroidrobots.com/shop/item.aspx?itemid=188
http://www.crestron.com/resources/product_and_programming_resources/catalogs_and_brochures/online_catalog/default.asp?jump=1&model=C2N-CAMIDSPT
It needs to hold a camera with 600gr.
My problem is that I dont know what are good specifications and bad specifications, so I need some guide lines in what I need and what problems I will find.
Can you help me?
Re: Pan/tilt motor specifications
« Reply #1 on: March 15, 2011, 12:04:08 PM »
Any of them should do then, the first one is probably the easiest one to use - the last one is overkill and have functions that you won't need.
What exactly will you be using it for?
Are you aware of how to control the servos?
« Reply #2 on: March 15, 2011, 04:28:42 PM »
Thanks for your reply.
Im going to use it to move the camera according the orientation of a imu. My idea is to change the imu orientation and the camera moves to the new angle.
I never worked with this kind of mottors and I'm not aware of what I have to do (complete newbie :s ).
Sorry for my basic english.
