Author Topic: $50 robot programming help  (Read 2251 times)
Offline MasterRykoTopic starter
« on: June 20, 2007, 09:56:28 AM »
Instead of having two servo motors, I have one servo motor in the front and one regular motor in the back.  I was wondering if anyone knew any good code that could help me with these two kind of motors.  Thanks!
Offline rgcustodio
Re: $50 robot programming help
« Reply #1 on: June 20, 2007, 11:09:27 AM »
You can drive the servo with minimum code and electronics, you just need to be able to create a pulse that is x milliseconds in width.
For standard DC motors you need a continuous current running to the motor which your MCU might not be able to provide or handle. That is why most DC motors require H-bridges. When you have an H-bridge running the motor is as simple as generating a PWM signal. So your first priority is sticking an H-bridge to your robot if it doesn't have any yet.
Search and read the forums:
http://www.societyofrobots.com/actuators_dcmotors.shtml
« Reply #2 on: June 27, 2007, 07:35:09 PM »
I'd recommend just buying a motor driver (that has an H-bridge already done for you). It'll save you tons of time.
(I know because I started motor control back when motor drivers were really expensive)
Last post December 31, 2007, 09:20:52 PM
by frank26080115
Last post May 24, 2009, 08:02:34 PM
by jaabot
Last post July 31, 2009, 11:56:47 PM
by apc3161
Last post August 23, 2009, 09:58:57 AM
