Author Topic: gluing HDPE?  (Read 1932 times)
Offline joe61Topic starter
gluing HDPE?
« on: March 27, 2011, 01:05:32 PM »
So far, Google tells me you can't really glue two pieces of HDPE together reliably. What would the best way be to join two pieces of it at a right angle?
I want to add a piece to the bottom of a chassis to which I can attach idler wheels. I have a couple of these. I'm thinking in terms of attaching an idler wheel to a robot with.
If I can attach a side piece to the bottom of the chassis, and drill holes for the sprockets, I can attach the idler wheels to it.
Joe
  • Helpful? 107
Re: gluing HDPE?
« Reply #1 on: March 27, 2011, 01:26:59 PM »
I doubt you can glue HDPE - or at least it wont be very strong. Other alternative, I guess, is to use a right angled metal bracket and screw the HDPE to that.
Re: gluing HDPE?
« Reply #2 on: March 27, 2011, 07:12:31 PM »
You might get away with welding it.
(You didn't hear it from me ;) but a clothes iron will probably be aces, if you don't have access to a hot air welder).
Offline nickc
Re: gluing HDPE?
« Reply #3 on: March 28, 2011, 02:53:34 PM »
for a right-angle joint your best best would be small aluminum or plastic angle bolted or pop-riveted to each piece.
Re: gluing HDPE?
« Reply #4 on: March 29, 2011, 03:52:10 PM »
Thanks all, I think I'm just going to use the right-angle brackets.
Joe
Last post October 01, 2006, 08:43:57 PM
HDPE
Started by rabi_tagore Misc
Last post March 03, 2007, 04:07:05 AM
by Eco19R
Last post January 26, 2009, 10:03:26 PM
Last post January 27, 2009, 12:06:32 AM
