Author Topic: How to detect a ramp ....... ??  (Read 1147 times)
Offline AndremahaTopic starter
« on: March 27, 2011, 11:00:21 PM »
Hi
i need a way to build my robot to detect a ramp and climb it which is on its way by using IR sensors. How can i do this ???
Please give me an advice.
my bot is line fallowing one which built using 2DC motors and IR....
Thanks !!!
Offline Metal Slug 2
  • Helpful? 11
Re: How to detect a ramp ....... ??
« Reply #1 on: March 28, 2011, 12:47:20 AM »
Hi Andremaha,
Without a clear picture of what your robot looks like or the course it must follow, I can only offer limited help.
There are several options available to detect the ramp.  It if it were up to me, I would use a simple mercury tilt switch.  A little more advanced, you can also use an accelerometer to detect acceleration of the robot and provide angle measurements for you to measure the slope of the ramp.  A flex sensor properly placed at the front of your robot could bend to indicate a ramp is ahead.  Or even the line detection sensors could be placed such that the ramp could trip them.
Offline Joker94
  • Helpful? 26
« Reply #2 on: March 28, 2011, 01:53:00 AM »
There a few more details that would be helpful.
     -what is the approximate size of the ramp?
     -What is the purpose of sensing the ramp(is it to increase power going up the ramp to maintain a speed)?
     -Are you able to add additional sensors  or can you only use the infrared?
     -When do you want to sense the ramp. when you are a 1' away or when the robot starts to hit the incline?
These basic points will play a big part in the recommendation of appropriate sensors for the application.
Offline mstacho
  • Helpful? 10
« Reply #3 on: March 28, 2011, 10:21:08 AM »
alternately, if you are OK with sensing the ramp once you're ON the ramp, you could use a gyroscope to detect whether the robot is tilted.  That would elliminate some of the problems with using an accelerometer (the biggest problem being: how do you use an accelerometer to distinguish between acceleration and the incline?)
MIKE
  • Helpful? 11
« Reply #4 on: March 28, 2011, 12:47:43 PM »
MIKE
Position the accelerometer such that one of the axis' is facing along the axis represented by up and downward motion (most commonly associated as a "z-axis"), instead of the xy planar axis that may be usually associated in correspondence to the floor.  Acceleration along the x and y axis should not have any effect on the z-axis.  Only in the circumstance that the robot is suddenly forced slightly upward by hitting the base of the ramp should the z-axis measure any change in G's.
Offline photomark
« Reply #5 on: March 29, 2011, 02:45:11 AM »
Another possible solution that involves tilt switches , get the smallest ones you can find and arrange as many as you can at slightly different angles , as your robot tilts the relevant switches are activated , the main difficulty with this is the accuracy is totally dependent of the quality of workmanship and the amount of switches used .
I really don't no if it would work , its just an idea I thought to put in as I read your question .
In many ways I have just described a type on encoder.
Why stop at detecting a slope , I also would want to measure it .
Offline greasemonkey94
« Reply #6 on: April 04, 2011, 11:58:37 AM »
hello,
using an accelerometer might your best bet.
However you could also use the IR sensor(assuming you're using the sharp ones) like this guy-->http://www.societyofrobots.com/robotforum/index.php?topic=11333.0
Last post May 26, 2011, 09:15:59 AM
by MaztorShake
Last post September 06, 2008, 09:18:37 PM
Last post May 30, 2011, 02:49:18 PM
by newInRobotics
Last post February 08, 2013, 04:10:21 AM
by Polemus
