Author Topic: Do you trust servos with plastic gears?  (Read 3061 times)
Offline S. KarimTopic starter
« on: June 20, 2007, 03:52:56 PM »
Some plastic gear servo's with over 100 torque end up being very cheap, 15-20 bucks. Do you trust them? Would you trust them for robotic arms or legs applications?
Re: Do you trust servos with plastic gears?
« Reply #1 on: June 20, 2007, 05:40:07 PM »
http://www.societyofrobots.com/actuators_servos.shtml#gears
Ive used probably 50 servos in the last 5 years, and only once did a gear crack. It was a plastic gear on a $13 Futaba s3110 microservo that I told to go back and forth a lot.
However Ive had the plastic output shafts crack on me probably 5 or so times (due to poor design and very rough treatment). I like metal output shafts much more for this reason.
You might also be interested in this post on servo lifetimes:
http://www.societyofrobots.com/robotforum/index.php?topic=1300.0
« Reply #2 on: June 20, 2007, 06:50:24 PM »
Is there any different between 51 oz/in torque with nylon gears and 51 oz/in torque with karbonite gears?
Offline ed1380
« Reply #3 on: June 20, 2007, 06:56:17 PM »
the gears are stronger and should last longer
Offline sdk32285
« Reply #4 on: June 20, 2007, 07:36:12 PM »
Hi
I have had many nylon gears strip and wear out when exposed to dirt and sand in outdoor mobile robots.
Last post April 26, 2008, 11:55:35 PM
by Private Reid
Last post October 01, 2008, 08:28:57 PM
by SeagullOne
Last post October 24, 2008, 07:57:02 AM
by Kirk
Last post February 28, 2012, 01:27:49 PM
