Author Topic: Which robotics system for is best me?  (Read 561 times)
Offline DavrosTopic starter
« on: March 27, 2011, 11:49:47 PM »
This is not a broad "which system is best?" question, and not intended to start a religious war; I just want to know what's best for me.
I have come to realize that non-techie people don't respond too well to tech descriptions. Even documents and PowerPoints presentations can leave them puzzled, but if you show them something physical then their eyes light up and they see not only what is in front of them but also many further possibilities.
So, I want to make a demo or two.
I develop software. It either works with the customer's existing hardware or I buy them some off the shelf hardware, and then I develop some software to speak to their hardware, an ODBC database (usually MySql) to store data and a browser based application to control the hardware and analyze the data, generate reports, trigger alarms, etc.
The sort of systems we are talking of are all surprisingly similar when viewed at a high level: asset/employee/vehicle tracking; stock control; data acquisition (reading of temperature, pressure, voltage, etc).
I could go on, but it's basically data acquisition/telemetry/SCADA/process control. At the hardware end can be RDIF tags, GPS sensors, Modbus and the like, etc, etc
So, what's a good system for me to develop some demos? A hard requirement is that the robot should not just load a program and go away and execute it independently of the PC. The robot should have some sensors and should report values to the PC program (which will add them to the database) and should also accept commands from the PC program (even if I have to develop my own command language and have the robot program interpret it).
And what might be some good demos? - a maze runner, where I can show the current location on in a desktop or browser program, with the robot representing an employee or a fork-lift ? (or even a vehicle & I could show it on google maps) - maybe it could pick up RFID tags and scan them (or carry them to a scanner) to identify them to the PC app and then move them form room to room, with new tags appears at goods inwards & disappearing at shipping? That would simulate stock control. - maybe stick some bright light or heat source, etc, somewhere and have the robot sense it? - allow the robot to be controlled from the desktop app or browser
any other ideas?
Offline mstacho
  • Helpful? 10
Re: Which robotics system for is best me?
« Reply #1 on: March 28, 2011, 08:05:35 AM »
I'm not sure about your budget or the size/professionalism you want to put into this, but you seem to want something more professional than just building it from scratch in your garage.  So:
http://www.robotshop.com/ca/white-box-robotics-extreme-914-pc-bot-11.html
Those are cool (although I've never used them), they are self-contained robotic development platforms that do just about anything (just add sensors...) and have a PC interface.  Since you develop software, in theory you can show your prowess at the various frameworks that these come in (I think the one I linked is a .net platform, but they have a linux one as well)
These (and similar platforms) are used quite a bit in research: http://www.robotshop.com/ca/coroware-corobot-cb-w-8.html  I've come across two of these, and they're generally nice if you want a small demo platform or if you're working with swarms.   Depending on how functional a robot you want to make, these platforms are really good (although it's up to you to supply sensors, for the most part, and write the code to use them).
Believe it or not, a lot of people are modifying roombas and controlling them via netbooks.  This is a much cheaper option and it can allow you to demonstrate swarm robotics applications.
As something else to look into, check this one out: http://www.robotshop.com/ca/robot-scout-wifi-mobile-development-platform-w-2-arms.html  That one seems to come with more sensors and functionality than others, but I can't speak to its usefulness since I've never used it.
« Reply #2 on: March 28, 2011, 08:34:19 PM »
Wow, that's, that's some good info. Thanks.
I am new here and notice a "helpful?" next to your post. Is there any way I can vote it up or add positive ffedback for you?
Offline rbtying
  • Helpful? 31
« Reply #3 on: March 28, 2011, 09:37:42 PM »
The [click for yes] link upvotes - there's no downvoting implemented.
Offline mstacho
  • Helpful? 10
« Reply #4 on: March 29, 2011, 06:52:46 AM »
Glad I could help.
MIKE
Last post August 31, 2008, 07:14:45 PM
by MarkBrown
Last post February 18, 2009, 04:26:58 PM
by pomprocker
Last post June 08, 2009, 05:15:24 AM
by sailos chamwapiwa
Last post September 27, 2009, 06:06:21 PM
by katob
