Author Topic: Gear reduction for small line follower  (Read 1366 times)
Offline ConscriptedTopic starter
  • Helpful? 10
« on: April 05, 2011, 03:17:57 PM »
I'm working on a small line follower. My goal for the overall size is aproximately 2x3 inches or there abouts. It's a personal project so the final details won't matter that much. Anyway I've gotten most of the parts worked out. I have a pair of THESE. I need to gear them down but I'm not sure how.
I'm looking for ideas on how to gear them down without building a custom gear box.
Conscripted
Offline MikeK
Re: Gear reduction for small line follower
« Reply #1 on: April 05, 2011, 03:44:21 PM »
Do away with gear reduction and drive the wheels by contact, like this:
http://elm-chan.org/works/ltc/ltc02.jpeg
Pager motors are mounted with the shaft in contact with the rubber robot wheels.
EDIT: Image got deleted (?) so am posting the link and description.
« Last Edit: April 06, 2011, 04:09:31 PM by MikeK »
  • Helpful? 10
« Reply #2 on: April 05, 2011, 07:03:43 PM »
I considered that but was a little worried about getting the pressure correct. Do you have any experience mounting tires this way? Any advice to give. Once I get this one working I'll build a smaller one using two of THESE.
Conscripted
Offline MikeK
« Reply #3 on: April 05, 2011, 07:37:58 PM »
Those second motors have a much lower operating speed.  The first ones absolutely need a large ratio reduction to be usable in a line follower.  They're not going to be swapable.
The only trick to getting that technique to work is having wheels that are a little soft, about like a pencil eraser.  Put them in and give it a try!  They still might be too fast, 10,000-31,000RPM is quite high.  See what 10% duty cycle will do.
  • Helpful? 10
« Reply #4 on: April 05, 2011, 08:31:56 PM »
I'll play around with it for a bit and see what I come up with. I know the second set of motors are a LOT slower. They are a tiny gear motor. For that project it will be all surface mount and a tiny battery. Thanks for the help.
Conscripted
  • Helpful? 84
« Reply #5 on: April 06, 2011, 08:47:52 AM »
I've built some small Bots and used the motor shaft in contact with the wheel. You do need to adjust the contact tension but it isn't take hard to do. This method does work very well.
Last post December 20, 2007, 06:05:55 AM
Last post August 16, 2010, 09:51:32 PM
by Hawaii00000
Last post December 15, 2010, 10:48:47 AM
by Conscripted
Last post December 17, 2010, 09:11:54 AM
by waltr
