Author Topic: Stepper motor voltage  (Read 3783 times)
Offline waldirTopic starter
« on: August 26, 2006, 10:40:34 AM »
I just got my first stepper motor, a Sanyo Denki 103H5210-0440. According to the specifications notes ( http://www.active-robots.com/products/motorsandwheels/stepper-motors/datasheets/103h5210-0440.pdf ), it should receive 3.96V at 1.2A/phase.
However, one of the manufacturer's detailed description shows graph of the torque at 24V and 36V (page 71 of this 3MB document: http://www.motiononline.com/SDC_PDFs/2step_e1.pdf#search=%22103H5210-0440%22 ).
So... what should I connect this motor to? Is the voltage not important?
waldir
Re: Stepper motor voltage
« Reply #1 on: August 26, 2006, 12:11:46 PM »
The chart on the motiononline.com datasheet (page 6) says that you need DC24V to operate the 2-Phase driver. The high voltage is for the driver circuitry, not the 4V stepper.
Anyway, the 24V is applied to the driver, and it steps down the voltage to drive your stepper. Check the pintout schematic on the driver to make sure.
. . . but in my humble opinion its kind of lame to carry 24V batteries on a robot for a 4V stepper . . . I guess they designed the driver that way to handle many different types of stepper motors.
You should consider maybe using a stepper driver IC that operates around the 4-7V range.
« Reply #2 on: August 26, 2006, 01:19:31 PM »
Oh, thanks for the explanation!
I'm about to experiment with this stepper driver: http://www.active-robots.com/products/motorcon/active-stepper.shtml
Am I right in thinking that I should connect my 7.2V battery in series with a 2.7 ohm resistor (added to the 3.3 Ohm/phase of the motor, it gives the 1.2A consumed by the motor)?
Thanks,
waldir
« Reply #3 on: August 26, 2006, 03:47:21 PM »
No, you dont need to add any resistors. The extra voltage will just overdrive your steppers a bit.
About overdriving, you should read my DC motor tutorial:
http://www.societyofrobots.com/actuators_dcmotors.shtml
Steppers and DC motors are basically the same when it comes to voltage rating.
« Reply #4 on: August 26, 2006, 04:32:58 PM »
Thanks !
That's very nice of you to have helped me so quickly :)
waldir
Last post July 13, 2007, 12:35:50 PM
by Steve Joblin
Last post August 21, 2007, 03:11:23 PM
by jsmoker
Last post September 05, 2007, 07:12:24 AM
Last post February 15, 2009, 09:32:27 PM
