Author Topic: Interfacing relay switch with RF receiver?  (Read 674 times)
Offline yoamocuyTopic starter
« on: April 08, 2011, 01:29:36 PM »
Hey, I was thinking about using a relay switch for something but I'm not exactly sure how to modify it so that I can hook it into the RF receiver.  Is it possible to interface a regular relay switch with RF without buying a set of RF relays?
Offline rbtying
  • Helpful? 31
Re: Interfacing relay switch with RF receiver?
« Reply #1 on: April 08, 2011, 02:04:06 PM »
You can use an R-C circuit to integrate the PWM signal (making it analog), and then a comparator (or a Schmitt trigger) to make sure it triggers at the point you want it to.
http://www.societyofrobots.com/remote_control_robot.shtml
http://www.societyofrobots.com/member_tutorials/node/83
« Reply #2 on: April 08, 2011, 04:33:24 PM »
Ok, so if I did that, that circuit set up would act as a relay so I wouldn't need to actually use one correct?
Offline rbtying
  • Helpful? 31
« Reply #3 on: April 08, 2011, 04:50:53 PM »
You'd still want a relay (or a MOSFET) to switch higher currents - all that circuit does is convert the joystick position received to a binary on or off.
Last post January 26, 2007, 10:40:58 AM
Last post April 14, 2008, 07:13:41 PM
Last post September 07, 2008, 09:12:58 AM
by ed1380
Last post November 10, 2012, 06:34:16 AM
