Author Topic: newb photo cell quetion  (Read 722 times)
Offline harpoTopic starter
« on: April 11, 2011, 08:24:24 PM »
i have seen photo cells (own a few) resist in the dark but let power flow in the light
are there photo cells that do the opposite?
if so can you send me a link to a shop for them?
Offline MikeK
Re: newb photo cell quetion
« Reply #1 on: April 11, 2011, 09:13:51 PM »
Offline vinniewryan
« Reply #2 on: April 11, 2011, 09:40:22 PM »
Though if you connect the output of a photocell to the base of a PNP transistor with a pulldown resistor, you've just basically reversed the photocell's output through the transistor to output high when there's no light, and low when there is.
« Reply #3 on: April 15, 2011, 10:12:15 PM »
LDR's (if that's what you're referring to have more resistance in darkness than in light and there are none that are opposite that.
How you use that function is up to you however and an inverting circuit will get you the opposite function.
Which circuit is the best depends on what you need, binary action (i.e. light/dark) or a linear varying output.
