Author Topic: $1 ball mouse ir sensor help  (Read 2054 times)
Offline blackbeardTopic starter
« on: April 14, 2011, 08:35:28 AM »
ok so here is my problem. i've never used 3 pin phototransistors and each of these $1 mice i bought has 3 of them, all not numbered. is there any way i can rig these for obsticle detection or at least line following?
Next step: Give them vaginas
Offline ballbreaker
Re: $1 ball mouse ir sensor help
« Reply #1 on: April 14, 2011, 11:20:06 AM »
there is a great tutorial here on how to make this here http://www.societyofrobots.com/schematics_infraredemitdet.shtml
follow the steps and them program it accordingly.
For Those About To Rock, We Salute You!
« Reply #2 on: April 14, 2011, 11:49:19 AM »
i found that but i'm using some sort of 3 prong photo transistor which i can't find much info on
Offline MikeK
« Reply #3 on: April 14, 2011, 12:38:38 PM »
Is it the U-shaped package that contains both the emitter and detector?  If so, the pins are probably 5V, 0V, and signal.  Use current limiting resistors.  You can find out which is the emitter by viewing it through a digital camera...With 3 pins there are only 6 combinations to try.
« Reply #4 on: April 14, 2011, 12:53:36 PM »
it's not inherently a U shaped package but the components are set up in that configuration. ok so one (which i assume is an IR led) has 2 prongs, is clear and apears to me like i diode. the other which i assume is a phototransistor has three prongs, is black and shiny on one side, the side that interacts with the other component
Offline vinniewryan
« Reply #5 on: April 14, 2011, 05:35:35 PM »
As stated above, in many cases the phototransistors with 3 pins are (1) V+, (2) GND, (3) output. Search google images for 'phototransistor' or 'IR sensor' and chances are you'll find many that look like yours complete with wiring descriptions. Definetely use resistors to protect the sensor, they burn up easily if you feed them too much current, especially when connected incorrectly.
To answer your question, yes, if the IR sensors are calibrated correctly you should be able to detect reflected light to discriminate between white and black lines based on the output voltage. If you can't figure the sensor out, you can pick one up from the shack to play around with for a couple bucks, or order them online for literally 5 cents each. They're cheap and easy to work with, I use 2-pin phototransistors on a weekly basis. There's so much they can be used for!
Also be aware that not all phototransistors will output a varying voltage, some are meant only to receive IR pulses and will output a very brief burst of output when the internal electronics have detected a certain condition of light. This is also common in mouse encoders, but they can be used in a different way to also detect black and white lines using more complex circuitry or code. Update us when you figure out what you have.
« Last Edit: April 14, 2011, 05:38:58 PM by vinniewryan »
« Reply #6 on: April 15, 2011, 09:38:18 AM »
alright i've reverse engineered the circuit in the mice to find the polarity and the basic circuit. IC that is supposedly logitec but the data sheet is nowhere to be found and the chips look cheep. in any case i'm going to try them for obstacle detection but they should at least work for line following. the irleds seem to be very dim even at 5v with a 100ohm though so i may have to add more
« Reply #7 on: April 15, 2011, 09:08:24 PM »
Well, thats a definity... Maybe.
Some 3 pin devices are regular photo transistors (i.e. emitter, collector and base), while others, particular in ball mice, is in fact two transistors in one housing (with one pin common). This will usually be the case if you see only one device on each side of the interrupter, as two are needed to give quadrature sensing.
Remember they're targeted for low current close range applications.
Unless you have several mice of the exact same build (sometimes the same model can have different parts), it probably isn't worth it, as buying the IR-LED's and -transistors you need won't be that expensive and then you get some with a full spec sheet, which will be easier to work with.
That said, yes, you can probably get them to work to some degree.
« Reply #8 on: April 16, 2011, 05:31:51 AM »
that's a good point. it would need to see what direction it's going after all. my original plan was to use them for a home brew joystick like thing.
« Reply #9 on: April 16, 2011, 12:20:49 PM »
Ahh, somehow I imagined a line sensor.
In that case it may be worth it even if you only have a single mouse, if you just want two axis like the mouse.
It will probably be a bit of a challenge to make the mechanical bits for a stick with interrupters for a two axis system though.
« Reply #10 on: April 16, 2011, 04:48:58 PM »
Oh ya well i got like 4 of them. It was only after examining the insides that i thought they might be useful for robotics as a sensor.
« Reply #11 on: April 16, 2011, 06:10:26 PM »
They are!
I strip any ball mouse coming my way, or at least toss them in the old_ball_mouse_box for later dismantling ;D
« Reply #12 on: April 18, 2011, 05:27:59 AM »
They are!
ya and after stripping all the rubber off the mouse balls i made an awesome newtons cradle!
Offline The arctic wolf
« Reply #13 on: April 18, 2011, 12:40:49 PM »
Hi everyone,
2 points I wanted to raise:
1. If someone wants help with a circuit that he visualy saw but we didn't, it will be helpful to upload a picture of the circuit, or the part.
2.  * Diodes(including leds) can be determined by a simple ohm meter because they allow current only in one direction.
* Bi polar transistors(NPN,PNP) can be determined by the ohm meter because their internal structure is basically like 2 diodes connected in opposite directions, 2 legged phototransistors(base don't have an output) will resemble a photoresistor in the category of changing their resistans based on lighting(can be cheked with an ohm meter also).
Hope it helps,
Andrei.
P.S. By the way always be careful and don't tuch the bear legs of sensetive transistors with fingers
because of static electricity of the human body.
« Reply #14 on: April 18, 2011, 05:51:22 PM »
[...] and don't tuch the bear legs [...]
Sensible advice  ;D
Last post April 04, 2008, 02:34:16 PM
by benji
Last post October 26, 2010, 02:02:42 PM
by andrea0206
Last post July 09, 2008, 12:25:52 PM
by krich
Last post November 18, 2010, 09:53:05 PM
by Redcap
