Author Topic: Reading/Writing to Axon II's eeprom  (Read 1048 times)
Offline BANETopic starter
  • E=roboticsC^2
« on: April 16, 2011, 12:16:38 PM »
Hello all,
just try to get my feet wet with reading/writing to my Axon II's eeprom.  Ive read all of webbots info (not sure if i understand it all yet, but hopefully will) and im getting some warning from AVR studio.
here is just the parts of code involving eeprom
//eeprom store var
int x_max_position;
//write to eeprom
x_max_position=10;
eeprom_write_byte(x_max_position, left_joy_x_max);
//display
rprintf("XMP=%d",eeprom_read_byte(x_max_position));
it gives me a warning saying:
warning: passing argument 1 of 'eeprom_write_byte' makes pointer from integer without a cast
also, returns the value 0, not 10
I read about having to include "EEMEM" in the variable but the compiler doesnt like it :P
Can anybody see my error?  probably syntax error
thanks,
« Last Edit: April 17, 2011, 07:10:56 PM by BANE »
Offline Webbot
  • Helpful? 107
Re: Reading/Writing to Axon II's eeprom
« Reply #1 on: April 16, 2011, 02:15:18 PM »
You definitely need the EEMEM in the variable definition.
If the compiler doesn't like it then you probably dont have
#include <avr/eeprom.h>
  • E=roboticsC^2
« Reply #2 on: April 16, 2011, 04:40:45 PM »
Ok, ive include that avr/eeprom but I still dont understand how to include EEMEM in the variables definition
uint8_t EEMEM x_max_position;  AVR studio says
error: section attribute cannot be specified for local variables
here is the new code:
eeprom_write_byte(x_max_position, 10);
Offline Webbot
  • Helpful? 107
« Reply #3 on: April 16, 2011, 06:40:10 PM »
I'm guessing that you are trying to do it wit a variable that is defined inside a function - which is a no no. It must be a global variable.
ie
uint8_t EEMEM globalVar; // Should be ok
void foobar(void){
    uint8_t EEMEM localVar; // Probably gives your error and cannot work
The difference is that 'globalVar' will always exist at the same memory location whereas 'localVar' comes and goes and is only valid whilst 'foobar' is running so can have a different memory slot every time its called.
  • E=roboticsC^2
« Reply #4 on: April 16, 2011, 07:44:51 PM »
ahhh i now know that global variables are :D
However, im still getting the two same warnings and every time i read and i get 255 not 10
TICK_COUNT appControl(LOOP_COUNT loopCount, TICK_COUNT loopStart) {
rprintf("LJM=%d",eeprom_read_byte(x_max_position));
return 0;
Can i use x_max_position like this inside TICK_COUNT?
Offline Webbot
  • Helpful? 107
« Reply #5 on: April 17, 2011, 06:35:06 PM »
when you compile your program you will be getting warning errors like this:
warning: passing argument 1 of '__eewr_byte_m640' makes pointer from integer without a cast
This is because you should be passing the address of your variable - not the contents of the variable - ie it should be prefixed with an '&' symbol. So try changing your code to this:-
eeprom_write_byte(&x_max_position, 10);
rprintf("LJM=%d",eeprom_read_byte(&x_max_position));
return 0;
C is a real pain with this stuff - and its made worse by the avr-gcc compiler just issuing them as warnings rather than errors.
  • E=roboticsC^2
« Reply #6 on: April 17, 2011, 07:10:40 PM »
yep that little "&" made all the difference :D
helpful+1
thanks a ton
  • Helpful? 86
« Reply #7 on: April 17, 2011, 08:44:23 PM »
Yep, this is called a 'pointer'.
For a better understanding see the K&R C book.
http://en.wikipedia.org/wiki/The_C_Programming_Language
http://www.amazon.com/Programming-Language-2nd-Brian-Kernighan/dp/0131103628
Last post January 15, 2009, 11:14:51 PM
Last post July 04, 2010, 06:29:21 PM
by KurtEck
Last post January 20, 2011, 11:49:20 AM
by mstacho
Last post November 03, 2011, 02:32:21 PM
by Mastermime
