Author Topic: recommand me some microcontroller boards pls  (Read 1668 times)
Offline SanglantTopic starter
« on: June 21, 2007, 08:28:09 PM »
hey, i'm looking for a microcontroller board that'll have 9 input and atleast 4 outputs.  of the 9 inputs, 1 is for gps, 1 is for digital compass, 1 is for ir range finder, 3 for acceleration, 3 for angel of rotation.  the 4 outputs are going to servos.  if it is possible, i would prefer the programing language to be C or C++ since it is a language i'm familiar with.  i'm thinking probably a board with around 8 ADC & 4 digital inputs, and 4 digital & analog outputs (i'm not sure if the digital servos uses digital input or analog).  thanks in advance for any advice
Offline megaman935
Re: recommand me some microcontroller boards pls
« Reply #1 on: June 22, 2007, 06:15:54 PM »
Wow that sounds pretty complicated for your first robot- unless of course you've made one before- If it is your first, I recommend K.I.S.S. (Keep It Simple Stupid  :P (I tried making a battlebot as my first robot.. BIG NO NO lol ;D ))
and probably digital (though I'm a noob so I can't tell you for sure.. ;) )
« Reply #2 on: June 23, 2007, 04:53:04 PM »
1 is for gps
hmmm so the GPS will require a serial connection. I dont think you will want GPS after you learn about its limitations. Search this forum for more info on GPS.
Most microcontrollers come with 8 analog to digital converters (ADC), so no problem with this. As for 'angel of rotation', do you mean gyro?
Can be made to work with an ADC, or done with serial. They arent very reliable.
most microcontrollers come with at least 8 digital outputs, so no problem.
check this:
http://www.societyofrobots.com/robot_parts_list_microcontrollers.shtml
or make your own:
http://www.societyofrobots.com/step_by_step_robot.shtml
as megaman935 said, if this is your first robot, you should take a step back and simplify your project (baby steps!)
Last post March 02, 2009, 10:39:55 AM
by BEAMer
Last post May 08, 2009, 08:35:28 AM
by SmAsH
Last post January 02, 2010, 04:34:29 AM
by Joker94
Last post April 19, 2010, 10:22:43 AM
by jensoverby
