Author Topic: oscilloscope recommendation?  (Read 4859 times)
Offline AdminTopic starter
« on: June 23, 2007, 12:18:31 PM »
Im thinking of buying an oscope for personal home use . . .
I want something relatively small and portable (under 5 pounds), and under $200. If it can connect to my laptop that would be great.
I want at least 1MHz bandwidth, and input range of at least +/- 25V, and have an automatic frequency counter. I like autoset buttons :D
Anyone with recommendations?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: oscilloscope recommendation?
« Reply #1 on: June 23, 2007, 12:33:20 PM »
Take a look at Zelscope. I know it's not 1MHz, but maybe with a attenuator...
« Last Edit: June 23, 2007, 12:38:20 PM by Ro-Bot-X »
Offline Eco19R
« Reply #2 on: June 23, 2007, 12:37:51 PM »
bitscope but its 400$
Offline Ro-Bot-X
  • Helpful? 25
« Reply #3 on: June 23, 2007, 12:45:40 PM »
Offline Brandon121233
« Reply #4 on: June 23, 2007, 02:07:55 PM »
        —Thomas Edison
Offline gamefreak
  • Robo-Enthusiast
« Reply #5 on: June 23, 2007, 03:50:07 PM »
the parallax one: http://www.parallax.com/detail.asp?product_id=28014
139 $
it has only 200 kHz
« Last Edit: June 23, 2007, 04:11:17 PM by gamefreak »
Offline rgcustodio
« Reply #6 on: June 23, 2007, 05:00:49 PM »
Depends on your needs and budget.
As others have mentioned Bitscope http://bitscope.com/ is cool. Its way cooler because the software can run on Linux!
There are others out there, like this one, http://microcontrollershop.com/product_info.php?products_id=1426.
Both do realtime display of data and can save to file for later analysis. Both have high frequency >= 50MHz support.
Am still checking my resources if I  should also get one :) I have a logic analyzer, my gripe is that it can display realtime data from the device under test, that's where the DSO comes in. The logic analyzer has decodings for common protocols, I2C, serial, SPI. Makes life easier.
« Reply #7 on: June 24, 2007, 07:42:23 AM »
For a serious 'scope, take a look at http://www.vellemanusa.com/us/enu/product/view/?id=522377
I'm quite satisfied with this, for some of what I do (although I'm more to having real knobs and switches) and paired with their signal generator, you can really get some work done (have to make do with their 1MHz generator so far though, since their PCGU1000 isn't released until around late August where I live, but still a nice setup).
Offline hgordon
  • Helpful? 7
« Reply #8 on: June 24, 2007, 07:49:16 AM »
I have the Embest DSO2300 2-channel USB scope - cost $350 and works well.
    http://www.armkits.com/product/DS2300.asp
Surveyor Corporation
  www.surveyor.com
Offline Steve Joblin
« Reply #9 on: June 25, 2007, 05:54:15 PM »
I have downloaded a few of those freeware O-Scopes that use the PC's sound card... they are not very good... well that was my thought until i found this one!
http://www.zeitnitz.de/Christian/Scope/Scope_en.html is AMAZING!!!! Very easy to use and very good!
If you are concerned about using your PC for fear blowing your sound card, you can check out this schematic ( http://forums.parallax.com/forums/attach.aspx?a=11536) on how to bulid a optoisolator circuit for your scope probe.
