2
Author Topic: Simple Robot with Camera  (Read 2830 times)
Offline tarushaggarwalTopic starter
« on: June 23, 2007, 12:44:32 PM »
i am pretty new to robotics...i have just made a simple line following robot using photoresistors.. Now i want to do the same thing using a camera...
i have a cheap ccd camera which just has the red output port ( normal AV wire port )... Can i use this camera??
if so how will i be able to configure it??
and will i still be able to use the ATMEGA16 that i used for the old robot??
i am totally lost as to how to connect the camera to the microcontroller!!.. Can anyone also suggest a good link where i will be able to learn the programming knowledge i will need to do the same....
Thanks,
Tarush
  • Helpful? 172
Re: Simple Robot with Camera
« Reply #1 on: June 23, 2007, 04:45:54 PM »
I recommend just buying a CMUcam or AVRcam (search for both in the forum/web)
Offline megaman935
« Reply #2 on: June 23, 2007, 05:39:01 PM »
AVR cam-
http://www.jrobot.net/
hope this helps!
Mega
« Reply #3 on: June 24, 2007, 06:33:51 AM »
i had planned to make a robot with a camera to follow a line..however i live in india and thus do not acess to the avrcam or the Cmucam...therefore i will have to make the development board myslef..
does anyone know how i will be able to this...i have a ccd camera and would prefer to use the atmega16.
i do not need any fancy image processing algo's i just want a very simple algorithm to follow a line.
please can somebody help me?
thanks in advance.
tarush
  • Helpful? 172
« Reply #4 on: June 24, 2007, 08:19:43 AM »
Both the AVRcam and CMUcam are open source and have both schematics and code for you to copy.
Have you checked out RoboRealm yet?
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #5 on: June 26, 2007, 03:04:36 AM »
John Orlando, the maker of AVRCam, told me that he ships worldwide and has many customers around the globe. So send him an email to get a quote on the shipment for your country. I'm sure he'll help you gladly.
