Author Topic: Disc slotted rotary encoder  (Read 1105 times)
Offline anh_risnTopic starter
« on: May 17, 2011, 08:44:41 PM »
Hi there,
Can anyone tell me where I can get disc slotted rotary encoder? I just searched on the net but still didn't find yet.
I just need to buy this slotted disc rotary encoder, and put it together with the phototransistor to read motor data.
Also, I am planning to put rotary encoder, I found from Hengstler RI58-D encoder
http://www.hengstler.com/gfx/file/shop/encoder/encoder_iiih_ri_58-d_en.pdf
Can I use as a wheel position sensor? The wheel rotate slowly but I need accurate data.
Also, the encoder has several type output, RS-422 and push-pull, it also has channel A, B, N.
What it's mean? Can anyone please help me?
Thanks,
« Last Edit: May 17, 2011, 09:57:11 PM by anh_risn »
Offline kl22
Re: Disc slotted rotary encoder
« Reply #1 on: May 18, 2011, 03:34:57 AM »
  • Helpful? 86
« Reply #2 on: May 18, 2011, 07:22:26 AM »
Older PC Mice used a slotted disc and photo-interrupter. You may be able to salvage the parts for your needs.
Offline blackbeard
« Reply #3 on: May 19, 2011, 04:11:07 AM »
the problem with that is that he would need to do allot of modification to make sure that he can attach the wheel to his drive system. a hot glue gun is recommended! if the speed is relatively fast i might recommend that a free method might be to use a hard drive motor. they make very good encoders as i have tested but only at higher speeds
Using Hard Drive Motor to Make Pretty LEDs Blink (aka rotory encoder with an op amp)
Next step: Give them vaginas
« Reply #4 on: May 20, 2011, 05:46:51 PM »
There is a number of encoder printing programs (and at least one.eps file for the sam purpose) floating around the net.
If you print one of these and glue it to a thin piece of aluminum plate, you can cut it out yourself.
You might be able to position the IR TX/RX well enough to use a coarse gear wheel as well.
If you take a stepper motor or a synchronous (mains) motor apart you should find a "comb wheel" that can be used either with IR or with a Hall sensor.
How many segments/holes do you need?
Last post September 18, 2007, 04:12:09 AM
by Tsukubadaisei
Last post December 07, 2010, 02:55:08 PM
by knossos
Last post November 12, 2012, 02:48:01 AM
by newInRobotics
Last post February 17, 2013, 11:24:13 PM
by jwatte
