Author Topic: 50$ Robot: expected identifier or '(' before 'while'  (Read 1146 times)
Offline nfwillTopic starter
« on: May 26, 2011, 08:34:12 PM »
Hello,
I have been following the 50$ robot tutorial and I have only the programming step left!
I added the Photovore_v1.c to source files under the AVR Studio, and followed the tutorial to the point of "Rebuild All"
At that point, I received 1 error and 3 warnings; the error being "expected identifier or '(' before while."
Here is the code that I copied and pasted in:
LED_off();//turn LED on
   while(1)
      //store sensor data
      sensor_left=a2dConvert8bit(5);
      sensor_right=a2dConvert8bit(4);
      //detects more light on left side of robot
      if(sensor_left > sensor_right && (sensor_left - sensor_right) > threshold)
         {//go left
         servo_left(44);
         servo_right(44);
      //detects more light on right side of robot
      else if(sensor_right > sensor_left && (sensor_right - sensor_left) > threshold)
         {//go right
         servo_left(25);
         servo_right(25);
      //light is about equal on both sides
      else
         {//go straight
         servo_left(25);
         servo_right(44);
      /* Servo Test Code
      i=250;
      while(i>0)
         servo_left(40);
         i--;
      i=250;
      while(i>0)
         servo_left(24);
         i--;
      //rprintf("Initialization Complete\r\n");
      //output message to serial (use hyperterminal)
      //print("Hello, World! Read My Analog: %u\r\n", sensor_0);
      delay_cycles(500);//a small delay to prevent crazy oscillations
My Intuition of my issue:
I have little knowledge of C; I am somewhat conversant in Python and Basic, I would think there must be "definitions" or parameters that I am missing. The code above is simply the bit that the downloaded Photovore_v1.c file shows to be added.
Any help is appreciated!
nfwill
Re: 50$ Robot: expected identifier or '(' before 'while'
« Reply #1 on: May 26, 2011, 08:42:49 PM »
It looks right . . . I suspect there is other code above or below that, which could cause a problem . . .
Also, try to match the line number of the error to the actual code.
Offline garrettg84
  • Helpful? 8
« Reply #2 on: May 27, 2011, 07:16:57 AM »
is LED_off() supposed to be a function?
the following code would make this a function
LED_off() {//turn LED on
   while(1)
      //store sensor data
         {//go left
         servo_left(44);
         servo_right(44);
         {//go right
         servo_left(25);
         servo_right(25);
      else
         {//go straight
         servo_left(25);
         servo_right(44);
      /* Servo Test Code
      i=250;
      while(i>0)
         servo_left(40);
         i--;
      i=250;
      while(i>0)
         servo_left(24);
         i--;
Based on code spacing and the trailing '}' you have either not copied the entire code, or the code you copied was bunk to begin with.
-garrett
Offline richiereynolds
« Reply #3 on: May 27, 2011, 09:52:09 AM »
Is that the whole file you're posting or a snippet? The whole file should probably have some #includes etc. at the top
« Reply #4 on: May 27, 2011, 09:08:57 PM »
Thank you for your responses Admin, garrettg84 and richiereynolds.
I first tried garrettg84's code; the compiler unfortunately complained and mentioned more 'undefined variables'.
My problem ended up being I read too much into the process, and richiereynolds implication that a 'snippet' can be the source of my issues helped. The code I did use was a snippet; complications I faced with AVR Studio caused me to use the snippet which at the time made a lot of sense: the 'entire code' mentioned using a specific part of its own code, perhaps I misunderstood. Getting the entire code into AVR through crude 'copying and pasting' rather than browsing through the files allowed it to successfully compile and functions correctly. I am very excited to be finishing up my first robot!
Thank you all for your time and help!
Much Appreciated,
nfwill
« Last Edit: May 27, 2011, 09:14:19 PM by nfwill »
Last post June 18, 2007, 09:50:46 PM
by ed1380
Last post February 05, 2008, 08:29:21 AM
Last post April 25, 2008, 07:16:35 AM
Last post November 28, 2009, 03:56:44 PM
by Joker94
