Author Topic: making an rc car  (Read 3711 times)
Offline andy bTopic starter
making an rc car
« on: June 24, 2007, 12:41:52 PM »
I have only recently started doing electronics but I would like to make a radio control car which can go forwards, backwards, left and right but i don't know if there is any specific software i should use and what types of servos i should use. Also if anyone could give me a circuit design which i could follow that would be very helpful.
Offline ed1380
Re: making an rc car
« Reply #1 on: June 24, 2007, 01:19:47 PM »
using car type (ackerman) steering or tank (diferential) steering?
if using a remote (transmitter), and a receiver made for rc cars, you won't need any software.
also the servos will plug into the receiver, but will have limited motion, unless you mod them.
my advice- get the transmitter, receiver, and ESC (electronic speed controller) and a motor.
if using ackerman steering also get a servo.
if using tank like, get 2 ESC and 2 motors
Offline maverick monk
« Reply #2 on: June 24, 2007, 05:52:47 PM »
if you want a rc car it would be the same price to buy a nice hobby grade rc car as it is to buy all the electronics seperatly and try to build your own chassis, also, hobby rc cars have alot of work put into them in the way of steering and suspension geometry.
small 18th scale ( <1 foot long) rc truck, great first truck, fairly fast, if you want somthing more specific i can help. if you insist on building from scratch, it might be best to start with a 2wd stadium truck so you can use the gearbox/differential from it and build a chassis to go around it
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJAY0&P=ML
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXPRE5&P=ML <onroad version
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAP3&P=ML < kit version ( assemble yourself and add your own electronics ( his list of electronics ^ once again, get more specific and ill help with that)
just be carefull, after you drive a nice one you are hooked... like me :)
« Last Edit: June 24, 2007, 05:54:02 PM by maverick monk »
« Reply #3 on: June 25, 2007, 12:48:15 PM »
How much would you expect this to cost becasue i don't have a huge budget
« Reply #4 on: June 25, 2007, 06:52:14 PM »
50 for the transmiter and reciever if you cheap out.. go to rc forums and ebay to find used speed controles, just make sure you get 2 of the same.
Offline megaman935
« Reply #5 on: June 25, 2007, 06:53:31 PM »
Ebay- definitely Ebay ;)
Offline TrickyNekro
  • Helpful? 15
  • 1.6L Peugeot 307 tuner
« Reply #6 on: June 26, 2007, 04:17:47 AM »
Of course you can make an esc yourself... look for esc schematics should you fing pleanty!!!
Cheers!
« Reply #8 on: July 01, 2007, 01:03:35 PM »
thanks for the help
