Author Topic: Transmitting analog video and audio signals?  (Read 1221 times)
« on: June 06, 2011, 03:04:00 PM »
I know that an atmel328 is simply not powerful enough to process video signals however i have bought CCTV video transmitters so that i may transmit directly to my tv. These transmitters are however pretty expensive so i'd lke to know if there is an inexpensive way that i could accomplish this same task rather then buying $40 transmitter and receiver sets?
Next step: Give them vaginas
Offline rbtying
  • Helpful? 31
Re: Transmitting analog video and audio signals?
« Reply #1 on: June 06, 2011, 05:04:22 PM »
$40.00 sounds about right - most setups are actually more expensive than that.  You could try getting a set with multiple transmitters and only one receiver, which would be cheaper per robot (presumably you don't need to show video on more than one screen).
« Reply #2 on: June 06, 2011, 07:37:21 PM »
i'm more looking to reduce the size and have a circuit integrated integrated into my project. would something like this work with the appropriate receiver?
http://www.sparkfun.com/products/8946
« Reply #3 on: June 06, 2011, 08:19:18 PM »
no
Offline billhowl
  • Helpful? 32
« Reply #4 on: June 07, 2011, 04:35:33 AM »
http://hackingelectronics.blogspot.com/2011/06/acquiring-images-from-analog-camera.html
Take a look on this, you may be able to send your video using that sparkfun transmitters if you don't mind the speed.
« Reply #5 on: June 08, 2011, 05:00:32 AM »
no
care to elaborate? :P
just saw that on HAD :P it might be worth looking into.
« Reply #6 on: June 08, 2011, 07:08:26 AM »
no
The OP implies that he has a a video camera that outputs an analog signal, either NTSC or PAL.
This requires several MHz of Analog bandwidth and the Transmitter/Receiver needs to modulate/demodulate this analog signal. The SparkFun transmitter he linked to is for digital signals up to 4800Hz.
The only way to use that transmitter is to digitize and capture a video frame then send that frame over the RF link. This requires additional circuits, would be very slow and maybe get a frame every few seconds.
