Author Topic: A Query About Flash Memory on Atmega8  (Read 803 times)
Offline brainwaveTopic starter
« on: June 07, 2011, 05:14:20 AM »
1.  How many times can i practically burn programs onto my flash memory on atmega8?
The data-sheet says 10,000 write/erase cycles.....but is it that i use only one cycle of the flash memory every time i erase or write a new program?
2. Does the size of the program count in the durability of the chips memory?
3. Does it have a mechanism that 'cycles' the memory locations used so that the memory wears out evenly, like in digicams and thumb drives?
//thanks for u'r time and replies! :)
Offline joe61
Re: A Query About Flash Memory on Atmega8
« Reply #1 on: June 07, 2011, 06:36:02 AM »
Do you mean EEPROM? There's an application note from Atmel that has some good information on this:
http://www.atmel.com/dyn/products/documents.asp?category_id=163&family_id=607&subfamily_id=760
Look for AVR101. There's a PDF and a link to some sample source code there too.
Joe
« Reply #2 on: June 07, 2011, 12:20:17 PM »
Yes, but it will possibly last longer than that (some may go sooner), although you probably won't ever get there.
Assuming an extremely extensive use, reprogramming the same chip ten times a day (each day) on average, would make it last for close to 3 years.
If you get to even halfthat number of read/writes, you're either obsessive or a real cheapskate  ;D
Not in a way that matters.
Nope (and neither of my way too many cams and too many thumb drives have this functionality AFAIK).
Last post June 28, 2010, 07:36:17 AM
Last post November 14, 2008, 01:46:07 PM
by bukowski
Last post January 20, 2009, 06:03:31 AM
by Webbot
Last post April 28, 2010, 05:47:11 PM
by corrado33
