Author Topic: Stupid servohorn question  (Read 2231 times)
Offline ribsTopic starter
« on: June 25, 2007, 12:15:33 PM »
It looks like every servohorn that I see online has predrilled holes all over them, whether it be on a 4-arm cross or a circle or a gear or whatever.  Are there special pins that are supposed to fit in there, or if not, what kind of screw is supposed to fit in there?  Home Depot, Ace Hardware, even RadioShack doesn't carry screws that small, as far as I can tell.  How are you supposed to use those?
Thanks.
Offline Eco19R
Re: Stupid servohorn question
« Reply #1 on: June 25, 2007, 12:43:48 PM »
You can always make them bigger with a drill.
« Reply #2 on: June 25, 2007, 03:11:18 PM »
Yep, I can do that easy.  I was just wondering if there was some standard servo pin or something (I didn't want to drill out the holes and then realize later that I had ruined the horn for whatever connector is supposed to fit in there).  If they are designed to be drilled out to fit any screw I want, then I am happy to do so ;)
Offline Steve Joblin
« Reply #3 on: June 25, 2007, 04:57:33 PM »
they are usually designed to accept a rod with a z bend (as in this pic... http://www.rtftechnologies.org/Design/Assets/device-images/fusor-mark3/construction/control/valve-mounted.JPG) or other servo links (as in this pic http://team-raptor.net/myraptor/r50v2/r50v2_images/r50v2_ail_servo2.jpg)
search on Servo links or servo linkages to see more examples.
Last post April 15, 2009, 08:44:57 PM
by Metal Slug 2
Last post September 04, 2009, 04:36:22 PM
by Joker94
Last post March 10, 2010, 08:03:54 PM
by Razor Concepts
Last post July 24, 2012, 05:24:21 PM
