Author Topic: linear position sensor?  (Read 1872 times)
Offline ribsTopic starter
« on: June 25, 2007, 12:31:15 PM »
I don't know if "linear potentiometer" is the term for what I want.  I wanted to determine the linear position of something in relation to something else (with more resolution than an optical encoder thing as described in the encoder tutorial), and did in fact find a bunch of linear position sensors online, but they are significantly more expensive than I thought they would be.  I figured since there is a rotary potentiometer contained inside a 3 dollar servo that buying one alone would be, you know, less than 3 dollars, not 90 dollars.
Anyways, can somebody point me at something that does what I want?  I don't know the correct electronic terms for anything, so I have a hard time googling for things.  I would even be happy making my own; it seems like all you need is two wires and a length of some consistent resisting material and it should be easy to graph out a lookup table in not too much time for X resistance = X distance between contact points on the resisting material, correct?
Thanks!
Offline JonHylands
Re: linear position sensor?
« Reply #1 on: June 25, 2007, 12:53:14 PM »
« Reply #2 on: June 25, 2007, 02:38:23 PM »
Yes, exactly!  Thanks.  Googling "slider potentiometer" got much better results than "linear potentiometer", which got me all sorts of expensive, fancy looking things like this.
Thank you,
Offline sdk32285
« Reply #3 on: June 25, 2007, 02:48:08 PM »
Hi
Another option is a Spring Pot.
http://www.micro-epsilon.com/en/Sensors/Draw-Wire/wireSENSOR-WPS-MK30-MK46-MK77/
These also give absolute position (ie. if you kill power than restart you can still tell where it is)
While this one can be expensive i have seen many home made versions that worked well and had very low cost.
Last post March 15, 2008, 05:25:08 PM
Last post November 30, 2008, 06:05:37 PM
by paulstreats
Last post August 11, 2009, 05:55:44 AM
by Ro-Bot-X
Last post November 13, 2010, 06:39:13 AM
by azy
