Author Topic: Using ports PB0 to PB3 as output although used for programmer  (Read 504 times)
Offline adanvascoTopic starter
  • Helpful? 6
Hi everyone. I recently got a sample LCD from Purdy Electronics http://www.purdyelectronics.com/products/displays/intchar.cfm (please use wisely ;)) and have been trying to connect it to the $50 robot.
My problem is that I need to use 4 consecutive ports ie. PB0 - PB3. This is a requirement of the library I'm using which can be found here http://extremeelectronics.co.in/avr-tutorials/using-lcd-module-with-avrs/. I could use the C port but I would have to sacrifice most of my ADC ports then.
So this is the question: can I use ports PB0 - PB3 which are currently being used to connect the hardware programmer? I know I'm not going to use the programmer while using the LCD, but I would have to configure port PB3 as output since PB0 - PB2 are currently not being used. So, changing PB3 to output would interfere with the programmer?
I forgot to mention, I'm using an ATmega8. I'm also open to new ways to achieve this. If you know of another library or a better way of doing this, please shout out!
BTW, the LCD is huge!!! It's almost an inch wider than my bot. It measures 4 1/2" by 1 3/4" by 3/5". But as we used to say in Cuba: "a caballo regalao' no se le mira el colmillo" ("Don't look a gift horse in the mouth")
Thanks.
Knowledge does not weigh.
Re: Using ports PB0 to PB3 as output although used for programmer
« Reply #1 on: June 15, 2011, 11:27:58 AM »
On the PIC you can use the programming pins, but need to "isolate" the lines a bit if they're used as output with lowish impedance loads - this is only when using ICSP, if you program it out of the board (like on a solderless breadboard), they can be used freely without any precautions.
I'd assume the same goes with AVR's (as long as you don't use a boot loader of course).
Especially when you selected the model yourself  :D
You could have gone for a 1x8 and you wouldn't have had that problem  ;)
  • Helpful? 6
« Reply #2 on: June 15, 2011, 01:03:42 PM »
Great! Thanks.
Yeah, I just got greedy  ;D. They actually have a smaller 2x16. I really didn't look at the physical dimensions as I (incorrectly) thought the size would be the same; dependant only on the number of characters. Now I know.
It actually came out better than I expected.
Thanks again Soeren.
  • Helpful? 84
« Reply #3 on: June 15, 2011, 02:11:44 PM »
I like your Bot.
  • Helpful? 6
« Reply #4 on: June 15, 2011, 05:09:56 PM »
Thank you. I used an old floppy disk drive case as the frame which is not very sturdy but at the same time is easy enough to work with. For the wheels I used two lemonade bottle caps. I was on a really tight budget and I think I managed to it make for around $30.
I actually got the LCD working  ;D
Edit: Forgot one more thing. The caster I took it from a mini roll-on perfume bottle.
« Last Edit: June 15, 2011, 05:16:08 PM by adanvasco »
Offline billhowl
  • Helpful? 32
  • Helpful? 6
« Reply #6 on: June 17, 2011, 06:54:03 AM »
Good deal! I actually thought of getting a serial LCD but were not available (not 100% sure) as samples. And they are way more expensive than the regular ones.
But this looks pretty interesting. It'll give it a try on my breadboard and see what comes out.
Thanks a lot!
Last post May 20, 2007, 10:49:15 AM
Last post November 26, 2007, 08:04:26 AM
by jsmoker
Last post June 23, 2008, 10:27:05 AM
by vidam
Last post November 28, 2008, 07:16:53 AM
by Bret
