Author Topic: Which bluetooth?  (Read 339 times)
Offline mlanderganTopic starter
Which bluetooth?
« on: June 18, 2011, 10:31:23 AM »
So I am planning on going wireless with my robots and I was wondering which one I should buy. I was looking at sparkfun and I found many blutooth. What qualities should I look for are some better than others? Also I intend to use the bluetooth for only about 100-150 ft and I am mostly going to use it for the arduino. This is what I found so far:
http://www.sparkfun.com/products/9358
http://www.sparkfun.com/products/582
http://www.sparkfun.com/products/10269
http://www.sparkfun.com/products/10393
Thanks in advance
  • Helpful? 84
Re: Which bluetooth?
« Reply #1 on: June 18, 2011, 01:21:14 PM »
I'd try going into the SparkFun forum and search for threads on each of these Bluetooth units.
That should give you a good idea to the Pros and Cons of each.
Offline Gertlex
  • Helpful? 23
« Reply #2 on: June 19, 2011, 09:06:14 AM »
For bluetooth, I would go with class 1 devices.
You might also consider using Xbees (the 1mW ones will be fine), especially if you need to do two-way communication.  If you're just sending signals from a laptop with bluetooth, you would just need one bluetooth serial adapter, but to do two way, you would need two.  The xbee solution is about $90 for two-way communication, compared to $120-140 for two class 1 bluetooth adapters...
If you give us more info about what you're going to do with the wireless connection, we can better point you in the right direction :)
I
« Reply #3 on: June 19, 2011, 04:02:44 PM »
If you want high range, you don't want a device with a trace antenna (like the ones in your links).
This is what I use:
http://www.sparkfun.com/products/158
http://www.sparkfun.com/products/145
Last post September 22, 2012, 06:40:19 AM
by streamlinedwings
Last post September 19, 2008, 08:28:09 AM
Last post September 04, 2010, 06:53:55 PM
by TheWiz
Last post March 10, 2011, 05:45:29 PM
