Author Topic: Questions about Axon II and L298 Driver  (Read 554 times)
Offline tzankoffTopic starter
« on: June 19, 2011, 01:59:53 PM »
Greetings, everybody!
I am in the planning stages for a new robot and have a couple of questions about the Axon II interacting with the L298 Dual Motor Driver.
I will be using 6V hobby servos as well as 12V gear motors. Obviously, I cannot plug 12V into the Axon because the servos will melt. However, I can plug a 6V battery into the Axon II and a separate 12V battery into the L298 bridge and that (as far as I know) will be fine as far as power in concerned.
My question is this: Do I need to plug in a 5V regulated power line from the Axon II into the L298 bridge pins as indicated at the bottom of "Wiring Diagram 2" of the datasheet (http://www.canakit.com/Media/Manuals/UK1122.pdf) *in addition* to the 12V input from the separate battery?
I believe the answer is yes, but the wording of the datasheet is ever so slightly confusing me for whatever reason...as usual. :P
Thank you for your help.
Re: Questions about Axon II and L298 Driver
« Reply #1 on: June 19, 2011, 03:43:18 PM »
Argh!! I got it. I must have skipped the line that tells me to "provide your own 5V DC regulated voltage" while reading the instructions. The answer to my question appears to be "yes". Onward...  ::)
« Reply #2 on: June 19, 2011, 03:58:32 PM »
It's good you got it answered.
Remember to make sure the grounds on all your stuff are connected, or it won't work. (people often make this mistake)
« Reply #3 on: June 19, 2011, 04:24:54 PM »
Oh, there you are. Hi, Admin. :::waves:::
Needles to say, I will be buying another Axon II pretty soon. Hooray for you! I just need to order all the chassis parts and get them in order and working before I employ the microprocessor or build anything else. I am building a robot similar to airman00's "Chives" and wolffan's "Belvedere" creations. Collectively (along with a few ideas of my own), they have the form and functionality I am looking for.
Last post January 31, 2008, 01:02:10 AM
by TrickyNekro
Last post January 17, 2009, 07:14:27 PM
by Webbot
Last post April 27, 2010, 11:41:46 PM
by Jak24
Last post December 26, 2011, 10:00:45 PM
by SzeHan
