Author Topic: what resisotor?  (Read 664 times)
Offline Mike11Topic starter
what resisotor?
« on: June 23, 2011, 12:03:27 PM »
does anyone know which resistor go with the photoresistors in the 50 buck project (340 ohm vs. 1.6 kohm)? I couldnt find anywhere Also, does it affect the robot in any way - I mean, can the software cope with both possibilities?
Thanks a lot
Mike
Re: what resisotor?
« Reply #1 on: June 23, 2011, 12:35:17 PM »
The resistor will depend on the resistance of the LDR. Measure the LDR value at max. light and max. darkness it will see and use a resistor value that is at the percentile middle.
That way it will have the largest range possible (as long as the value isn't adjusted dynamically, which would be a project in it's own right).
