Author Topic: summing amplifire resistor selection  (Read 444 times)
Offline aruna1Topic starter
  • I'm an Ordinary guy
« on: June 28, 2011, 05:36:36 AM »
hi
I'm making a non inverting summing amplifier using LM324. I will be adding 5V inputs (supplied using micro controller pins to get voltages 5,10,15,20 from summer) since all the resistor values are equal, is there any procedure to select a proper resistor value ? see the attachment
thank you.
« Last Edit: June 28, 2011, 05:42:11 AM by aruna1 »
I'm Me
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
Re: summing amplifire resistor selection
« Reply #1 on: June 28, 2011, 06:35:57 AM »
Every op amp has a very small but existing biasing current. Keep that in mind when selecting resistors for op amps generally.
So taking that into consideration, you select feedback resistors accordingly.
But yes, if you don't have any extreme power consumption requirements the 10 - 100 kOhm range usually works with most op amps
Cheers!
Last post March 26, 2009, 04:56:46 AM
Last post October 24, 2009, 08:47:38 AM
by Kylepowers
Last post December 05, 2010, 10:45:00 AM
by waltr
Last post February 06, 2013, 03:11:02 AM
by Inigo Montoya
