Author Topic: serial communication in H8S2633R  (Read 532 times)
Offline wowlaTopic starter
« on: June 29, 2011, 10:20:02 PM »
I have problem in writing the program code in the serial communication between the 2 H8S2633R. Basically, I want to send information from 1 of the processor to the other and I am send through a max232.
  • Helpful? 84
Re: serial communication in H8S2633R
« Reply #1 on: June 30, 2011, 07:01:17 AM »
If both H8S2633R's are close together (short wires) then you do not need a to convert to RS232. the two H8S2633R's can be directly wired.
If they are far apart, more than a meter, then do you have a MAX232 of each H8S2633R?
Try getting one H8S2633R serial communications working to a PC com port, with the MAX232, using a terminal program. This is much easier to troubleshoot and debug. Once this works then connect the two H8S2633R's together.
« Reply #2 on: July 03, 2011, 11:54:12 PM »
Then how about the program code? I still cant make it communicate with the PC.
Last post May 02, 2007, 05:02:10 AM
Last post July 12, 2007, 05:23:54 AM
by henry
Last post January 14, 2008, 02:52:59 AM
by bootstrap
Last post January 26, 2009, 02:13:34 AM
