Author Topic: [SOLVED]::Persistent variables in the Axon  (Read 451 times)
Offline mstachoTopic starter
  • Helpful? 10
« on: July 12, 2011, 08:18:18 AM »
Hi all,
I was certain I'd posted this before, but I searched all my previous posts and couldn't find it, so *super* sorry if this is one of those common questions that comes up all the time!
Here's my issue:
I'm using webbotlib.  The Axon is responsible for determining whether my robot should be working in "position" mode or "force" mode.  The switch between these two modes is a threshold on the force sensor: the robot keeps moving to a certain position unless the force on the sensor exceeds a threshold, at which point it starts to regulate the force at some pre-set value.
That threshold is going to have to be variable, and what changes it is a message from the PC.  So far, so good -- I can easily send data back and forth from the PC to the Axon.
However, since the threshold is just a variable that gets created each time the Axon goes into the "appControl" function, it also gets destroyed each time I exit that loop.  If the threshold were never changing, I'd just #define it as something.  I need to be able to set the threshold whenever I want, without having to re-set it each time I go through the appControl function.
So: PC sends a new threshold, Axon receives it, and should set that threshold and keep it, regardless of whether it exited appControl, until a new threshold is received.
How do I do that? :-P
MIKE
« Last Edit: July 12, 2011, 09:36:26 AM by mstacho »
Offline rbtying
  • Helpful? 31
Re: Persistent variables in the Axon
« Reply #1 on: July 12, 2011, 08:53:08 AM »
Put it on top of the program, outside of the various functions and such:
uint8_t threshold;
void foo() { threshold = 0; }
void bar() { ++threshold; }
  • Helpful? 10
« Reply #2 on: July 12, 2011, 09:35:17 AM »
Awesome!  That was way simpler than I expected, thanks.
MIKE
Last post February 20, 2009, 09:13:44 PM
Last post April 27, 2011, 05:19:28 PM
by tzankoff
Last post February 28, 2011, 01:57:19 PM
by CalamariDudeMan
Last post December 12, 2011, 12:49:58 AM
by Rent2Own
