Author Topic: about 3.3V microcontrollers (do you have concerns?)  (Read 577 times)
Offline AdminTopic starter
« on: July 16, 2011, 03:54:48 PM »
The new soon-to-be-released Axon Mote, using 3.3V, has caused some controversy.
To find out more, see here:
http://www.societyofrobots.com/robotforum/index.php?topic=12650.120
If you have concerns about 3.3V, post it here and I'll do my best to alleviate (or confirm) your fears :P
Offline joe61
  • Helpful? 16
Re: about 3.3V microcontrollers (do you have concerns?)
« Reply #1 on: July 16, 2011, 04:02:21 PM »
I confess I'm not entirely sure what the Mote is for quite yet, but I'm guessing that the row of three-pin connections are for servo/pwm type devices?
I'm interested in building something like this http://www.youtube.com/user/RyanPololu?blend=2&ob=5#p/u/1/-27CQ_d7YSg
However, I'd like to be able to have a few of these around the room, and control them from a base station with a T.V. remote, using an XBee controller. I like the Mote for this because of its wireless capability, but I'm not sure if 3.3 volts will be enough to drive the LEDs? Being that I'm Not Qualified as an engineer, is this actually a problem?
Joe
« Reply #2 on: July 16, 2011, 04:54:14 PM »
You can find detailed info on the pins here:
http://www.societyofrobots.com/axon_mote/axon_mote_datasheet.shtml
(rough draft at the moment)
You will need to look at the datasheets for your LED's + electronics. The RGB LED Satellite Module 001 in the video "requires 9 to 10 VDC at 100mA", so you need an LED driver to use it. This will be a problem even with 5V microcontrollers. You just need to find an LED driver that accepts 3.3V commands (the ShiftBar driver in the video requires 5V).
« Last Edit: July 26, 2011, 01:26:10 PM by Admin »
Offline joe61
  • Helpful? 16
« Reply #3 on: July 16, 2011, 08:03:35 PM »
I've got a couple of these http://www.sparkfun.com/products/8745 lying around, maybe I could use those somehow.
I'll take a look at the link you sent.
Joe
Last post February 26, 2007, 10:30:32 PM
by JesseWelling
Last post April 08, 2007, 11:51:49 AM
by Brandon121233
Last post May 18, 2007, 09:43:10 AM
by iLL_LeaT
Last post June 25, 2009, 08:00:50 AM
by mdmedlin
