Author Topic: The best way to wirelessly connect to your robot from distant?  (Read 1018 times)
Offline SylvestreTopic starter
  • Helpful? 12
I'm looking for the best way to control your robot from about 3000 feet away?  I also need to transmit live video.
Offline ofnature
Re: The best way to wirelessly connect to your robot from distant?
« Reply #1 on: August 08, 2011, 08:02:15 PM »
control it by wifi, add a dish to your wifi router.
http://en.wikipedia.org/wiki/Cantenna is good enough
  • Helpful? 12
« Reply #2 on: August 08, 2011, 08:46:41 PM »
Is this the best route for me to take?  Also there will be plenty of buildings and walls inbetween the robot and pc
Offline adanvasco
  • Helpful? 6
  • Necessity is the mother of invention.
« Reply #3 on: August 08, 2011, 09:58:23 PM »
What about cell phone control? More costly but best suited for outdoors and any distance.
Knowledge does not weigh.
  • Helpful? 12
« Reply #4 on: August 08, 2011, 10:06:32 PM »
I have been recommended a drone cell, but this cannot transmit video.
Offline adanvasco
  • Helpful? 6
« Reply #5 on: August 08, 2011, 10:21:05 PM »
Transmitting video with obstacles such as buildings will get very expensive for sure. What about sending images through mms every few seconds? Not live video but something.
  • Helpful? 12
« Reply #6 on: August 08, 2011, 10:23:14 PM »
Would wifi work though?  Or does that not get good reception in the city/  I would probably only need 1500 feet with buildings.  What about rf modules?  I've heard about them, not sure how to use them.
« Last Edit: August 08, 2011, 10:34:57 PM by Sylvestre »
Offline ofnature
« Reply #7 on: August 10, 2011, 09:35:37 AM »
http://www.usbwifi.orconhosting.net.nz/ with a range up to 5 kilometers.  Being in the city won't matter, with the right dish you can boost a wifi signal 50 plus miles.
  • Helpful? 12
« Reply #8 on: August 10, 2011, 11:56:35 AM »
ok I will definitively consider your suggestion.  Thanks!
« Last Edit: August 10, 2011, 12:00:15 PM by Sylvestre »
« Reply #9 on: August 10, 2011, 03:44:50 PM »
Your posts seem to be too related . . . here is a cross-reference . . .
http://www.societyofrobots.com/robotforum/index.php?topic=14283.0
Offline robotgoldfish
« Reply #10 on: August 11, 2011, 06:31:49 AM »
You might want to check the wifi coverage in the operation area of your bot.  It might be able to control the bot over the internet using existing hotspots.  Or you could even carry wifi routers and drop them to act as boosters when the signal got week.
  • Helpful? 12
« Reply #11 on: August 11, 2011, 04:08:46 PM »
Could I use this transmitter and receiver to transmit video?  If so, what camera can I use?  Also how could I hook a batter yup to it instead of using the wall transformer
 http://www.123-cctv.com/seccams/trans.html
« Last Edit: August 11, 2011, 04:28:23 PM by Sylvestre »
« Reply #12 on: August 11, 2011, 05:36:03 PM »
yes
Any kind with a compatible cable connector.
Measure the voltage of the wall transformer, then use a battery of the same voltage. You can probably even use a lower voltage. Just cut the power supply wire and attach a battery plug to that wire.
You will also need a TV to view the images, or an adapter that lets you view the video by USB to your computer.
  • Helpful? 12
« Reply #13 on: August 11, 2011, 08:41:57 PM »
Yes!!!  Finally I have found a solution to my camera!  It says it can connect to a monitor so will I be able to connect it to my parallel port?
« Reply #14 on: August 11, 2011, 09:32:01 PM »
ehhhhh if it has a parallel port connector, then yes. Otherwise, you'd need an adapter :P
  • Helpful? 12
« Reply #15 on: August 12, 2011, 12:27:08 PM »
Also is there a way I can use the axon II's on/off switch to turn that on also, or am I going to have to use two switches?
« Reply #16 on: August 12, 2011, 01:11:39 PM »
Only if they use the same battery can you use just one switch.
Last post December 26, 2008, 12:32:09 PM
by jamort
Last post June 30, 2009, 09:14:16 AM
by BEAMer
Last post February 19, 2010, 10:00:08 AM
by parallax
Last post February 10, 2013, 10:39:26 PM
by greywanderer012345
