Author Topic: Programming Axon II in Project Designer  (Read 508 times)
Offline NGuggemosTopic starter
« on: August 29, 2011, 08:40:06 AM »
I'm programming the Axon II in project designer using Webbotlib.  When it asks for my battery and I'm using a switching regulator should I type the output voltage and current of the switching regulator or should I put the initial voltage of my battery?
Offline Webbot
  • Helpful? 107
Re: Programming Axon II in Project Designer
« Reply #1 on: August 30, 2011, 07:24:56 AM »
Yep - enter the output voltage and current of your supply - ie what you are going to 'plug in' to the AxonII.
« Reply #2 on: August 30, 2011, 08:41:50 PM »
So I should enter the voltage and current after its regulated by the switching regulator?
« Last Edit: August 30, 2011, 08:45:19 PM by NGuggemos »
Offline Webbot
  • Helpful? 107
« Reply #3 on: August 31, 2011, 09:36:13 AM »
Yes
« Reply #4 on: September 01, 2011, 04:01:11 PM »
ok thank you
Last post November 14, 2010, 06:54:46 PM
Last post January 23, 2011, 07:36:44 PM
by Webbot
Last post March 16, 2011, 04:43:08 PM
by raptorwes
Last post December 02, 2011, 09:11:40 PM
