Author Topic: Motor selection question. Confused.  (Read 315 times)
Offline Croy9000Topic starter
« on: September 07, 2011, 02:04:02 PM »
Ok, I am confusing myself on motor selection for a small bot. Hopefully someone can set me straight.
Here are the values I'm entering into the RMF calculator:
Mass: 3lbs
Desired Velocity: 3ft/s
Desired Acceleration: 1.5f/s2
Expected Efficiency: 65%
Incline Angle: 0
Wheel Diameter: .06m
# of Powered Wheels: 2
It tells me my RMF is 1.65, and my Rotation is 291rpm. Maybe I am using the calculator wrong, but in the Motor Characteristics section I enter 300 for RPM and play with the Torque value until I get close to my required RMF, which comes out to about .35lb-ft (67.2ozf-in according to this). I take this to mean how much torque I need to achieve my desired acceleration.
Now here is where I get confused (or maybe I was already confused above). I go to http://www.robotshop.com/dc-motor-selection.html and enter the same values. It tells me my torque is 2.0329ozf-in. I take this to mean how much torque I need to achieve my desired acceleration.
2.0329ozf-in is way less than 67.2ozf-in. Where am I going wrong?
« Last Edit: September 07, 2011, 05:12:19 PM by Croy9000 »
  • Helpful? 84
Re: Motor selection question. Confused.
« Reply #1 on: September 07, 2011, 06:10:27 PM »
I put your numbers into both calculators. The one on the RobotShop gave me a torque of 4.06ozf-in, not the 2.03ozf-in you came up with.
This is still much different than the SoR calculator so I'll guess one or the other (or both) have errors in the calculations and/or make different assumptions. Both have a tutorial that goes through the calc's, maybe go through each to find the discrepancy.
« Reply #2 on: September 07, 2011, 07:04:24 PM »
The SoR calculator use wheel diameter, while the RobotShop calculator use wheel radius (which is why you got ~4ozf-in.
The rest of the differences is probably due to them not expressing the same thing.
« Reply #3 on: September 07, 2011, 08:01:20 PM »
Yep. Although one seems to indicate I need an a significantly more powerful motor than the other. I am sure I am just missing something though.
Last post March 29, 2008, 10:10:01 PM
Last post December 19, 2009, 11:04:50 PM
by ukesh
Last post December 05, 2010, 10:12:26 AM
by waltr
Last post August 31, 2011, 10:54:19 AM
