Author Topic: Reproduce the sonar sensor system of robot vaccum cleaner  (Read 699 times)
Offline doly77Topic starter
« on: September 09, 2011, 02:24:18 PM »
As the title say, I would like to reproduce the sonar sensor system that we can find in most robots vaccum cleaner.
It doesn't seem very difficult to reproduce but I'm a beginner and I need some help in order to know what component to use.
I already know that I need :
- 4 Devantech SRF04 Ultrasonic Range Finder
- 1 Parallax BASIC Stamp 2 Microcontroller
- 1 Parallax BASIC Stamp 2 Carrier Board
What should I use in order to powered the BASIC Stamp 2 and the 4 SRF04 ?
Do I need anything else ?
Offline rbtying
  • Helpful? 31
Re: Reproduce the sonar sensor system of robot vaccum cleaner
« Reply #1 on: September 09, 2011, 05:53:26 PM »
Most robotic vacuum cleaners don't have sonar... at least, the Roomba series doesn't, nor the Neato ones.
Anyways, you probably want a battery pack and an appropriately rated switching regulator--those ultrasonic rangefinders can draw quite a bit of current when generating pulse. You might be able to get away with a linear regulator though, since it's a very low duty cycle load.
« Reply #2 on: September 10, 2011, 03:42:33 AM »
Thanks for your answer.
I was thinking add an external 5V Regulator.
You said that most robotic vacuum cleaners don't have sonar, do you know what they use instead ?
Offline rbtying
  • Helpful? 31
« Reply #3 on: September 10, 2011, 09:35:26 AM »
Roombas crash into things and use a bump sensor to detect the obstacle, then turn away from it. The Neato XV-series uses a scanning laser rangefinder and mapping algorithms; however, there's no cheap way to do this--people actually buy the Neato 'bots to get the laser scanner, since the cheapest commercial version is around $1100.
« Reply #4 on: September 11, 2011, 07:24:19 AM »
Ok, thanks for your answers.
Last post November 04, 2008, 07:13:13 PM
by paulstreats
Last post November 21, 2008, 04:27:23 PM
by Rebelgium
Last post June 07, 2011, 04:13:18 AM
by MaztorShake
Last post November 07, 2012, 01:19:39 AM
by alashmori2009
