Author Topic: $50 Robot Questions  (Read 383 times)
Offline yeohTopic starter
$50 Robot Questions
« on: September 13, 2011, 02:14:38 AM »
In the $50 Robot, part 3B. It says to solder the wires and stuffs together. My question is, how can we know which port is in which wire. Like how do we know what port is each pin? and also what does the wire do?
Another question is when we put the photoresistor in, which pin do we put it in? Why do we put it there?
Offline Conscripted
  • Helpful? 10
Re: $50 Robot Questions
« Reply #1 on: September 17, 2011, 09:48:29 AM »
I'm afraid I don't understand this question. Can you re-phrase it?
All of the port designations and functions are covered in the data sheet for any given micro controller. This tutorial uses the ATMEGA8 micro controller. You can look at it's data sheet HERE
Wire is used electrically connect components.
THIS forum post might make it a little easier to see what goes where. The photoresistors could be moved to different pins without changing the function of the robot if you change the software that controls the robot.
Last post May 17, 2008, 06:28:34 PM
Last post October 07, 2008, 11:01:32 PM
Last post October 26, 2008, 05:51:16 PM
by izaktj
Last post March 03, 2009, 11:06:49 PM
by Metal Slug 2
