Author Topic: Roboduino Bluetooth  (Read 830 times)
Offline Adityav95Topic starter
Roboduino Bluetooth
« on: September 18, 2011, 07:07:48 AM »
Why is this bluetooth module so cheap?
 http://www.ebay.com/itm/Arduino-Bluetooth-Module-Slave-Wireless-Serial-Port-4P-/220852015499?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D2866999681675276453
When comoared to something like:
 http://www.sparkfun.com/products/582
Q2. Should i buy the ebay one or this one:
      http://www.sparkfun.com/products/10253
I will be using any one of the modules to use voice control via android to my roboduino and as u might have guessed i dont want to spend more than $15.
Thnx
Aditya
« Last Edit: September 18, 2011, 07:10:15 AM by Adityav95 »
Offline richiereynolds
Re: Roboduino Bluetooth
« Reply #1 on: September 19, 2011, 01:56:27 AM »
Can't comment on this exact model but I'd try to get some reports from someone who's bought one. I bought a cheap DF Robot bluetooth module on ebay that never worked, wasn't dear but wasted a lot of my time. Whereas I've had two more expensive ones that worked without any bother, which was definitely worth the extra cash!
By the way, if you do buy it, remember to report back here how it went for the benefit of the rest of us bargain hunters!
« Last Edit: September 19, 2011, 02:02:25 AM by richiereynolds »
« Reply #2 on: September 19, 2011, 08:49:02 AM »
So is this better at least?
I really cant spend more than $15. So its the ebay module or this one.
And by the way....for bluetooth all i need is one of the above mentioned chips and a computer with bluetooth right?
And it WILL BE compatible with roboduino?
Thnx
Aditya
Offline joe61
  • Helpful? 16
« Reply #3 on: September 19, 2011, 10:29:47 AM »
Others here know more than I do about this, but when I tried bluetooth I found that I had to have at least one class 1 adapter. Since I was only sending from a PC I put the class 1 adapter on the PC. Even so I had limited range, and frequent disconnections. The cost of the eBay module may mean that it's a low power unit. if the android doesn't have a class 1 adapter, you may need this one to be.
Joe
Offline Gertlex
  • Helpful? 23
« Reply #4 on: September 19, 2011, 10:59:16 PM »
The one on eBay is a class 2 device, so range is going to top out at 10 meters (30ish feet).  Not something you want for a moving robot (because anything in between your computer and robot is going to have a good chance of completely breaking the connection).
As best I've been able to find, using bluetooth serial connections with windows is a 1-way connection thing... E.g. can send, or receive data only.  Supposedly there are work arounds, but I've been unable to find them.
As for why so expensive... I really don't know, but the prices haven't dropped on this hardware in the 5 or so years I've been watching... :/
(My alternative recommendation is to use Xbees, but that's $80 + shipping for the two xbees, and the two adapter boards for them)
I
« Reply #5 on: September 20, 2011, 04:47:31 AM »
1. Then will this do? I'm really streching my budget here.
 http://www.sparkfun.com/products/8497
2. Is this module all i need to connect to my roboduino? Like do i need anything else at all to add bluetooth connectivity?
Re: Roboduino Bluetooth and Android
« Reply #6 on: September 22, 2011, 08:21:10 AM »
Could someone pls tell me how do i use my android to control the robot? like is there any app? ive heard of an app called cellbot....but not sure...
Thnx
Aditya
« Reply #7 on: September 22, 2011, 06:57:20 PM »
It just didn't occur to you to write "cellbot" in a Google search?  ::)
« Reply #8 on: October 10, 2011, 08:15:23 AM »
Firstly, as Gertlex said 30 feet is too low a range. Therefore I have decided to go with something better. Some questions:
1. Any idea how good the RN-41 bluetooth module is?
2. Would I need a breakout board as the module with breakout board costs $35 more than just the module?
3. How hard is it to use the module with the roboduino without a breakout board?( Is it tooo hard?)
I would also like to know why a WT-41 module from blue-giga costs only $40 but also has a whopping 1000m range? Will someone tell me whether I will need anything other than this module to 'bluetooth enable' the roboduino??
Thnx a lot for answering (and for being patient!) :)
ADITYA
« Last Edit: October 10, 2011, 08:16:47 AM by Adityav95 »
Last post September 22, 2012, 06:40:19 AM
by streamlinedwings
Last post September 19, 2008, 08:28:09 AM
Roboduino
Started by offy Software
Last post February 19, 2009, 02:53:41 PM
by offy
Last post March 18, 2009, 04:46:10 PM
by airman00
